Nice TunerTools, that's the exact kind of example I was looking for... and the results I was afraid of.Originally Posted by TunerTools
In order to loose that much detail it must be only captureing a value every half-second or so... or worse.
However, in order to complete the loop, we'd need to test the same set-up with the Mongoose cable to see if it was the serial connection that was indeed causing the bottleneck. Or perhaps it was the software (PCMSCAN) that couldn't poll and record quick enough and a faster cable would hardly help at all.
Maybe someone with a Mongoose cable and PCMSCAN can provide some input to compare to your son's experience.
I'd say a device that can't keep up with a car's many rapidly changing dynamics, such as RPMs, can't be considered a truly accurate "real-time" analyzing tool. It would be better suited for discrete diagnostics (like engine alarms) or slow-changing parameters (like temperatures).
LinkBack URL
About LinkBacks
