Results 1 to 4 of 4
Thread: 1994 Camry V6LE Partial OBDII?
    Nov 2005
    Well i've been doing research on my camry's engine. At first when I was reading about OBD-II it said it was in cars AFTER 1994... So I didn't bother looking into it...
    Then I read on wikipedia that that 1MZ-FE (the engine in my camry) was the first engine ever to be OBD-II Compliant, but at the same time, it was only partially OBD-II compliant.
    My question to the experts out there, can I still use hardware available from scantools.net or whatever it is i'm supposed to use and pull stats? What kind of stats can I pull?
    Any info on this would be greatly appreciated.
    Again info on the engine is as follows
    Engine make: Toyota
    Engine model: 1MZ-FE V6
    Car make: Toyota Camry 4dr. V6 LE
    Car year: 1994
    More info from wikipedia:
    The 1MZ-FE is a 3.0 L (2994 cc) engine. Bore is 87.5 mm and stroke is 83 mm. Output is 188-210 hp @ 5200-5400 RPM with 203-213 ft·lbf of torque at 4400 RPM. It has bucket tappets , and incorporates camshaft, and head designs for good economy, without an overall performance trade-off. It happens to be the world's first partial OBD-II compliant engine, and the world's first fully compliant OBD-II engine.
    1999 Lexus GS300- (going VIP)
    1993 Lexus SC300-Turbo (Totaled by idiot driver)
    1996 Lexus SC400- (Totaled by brother)
    1972 Datsun 240Z- (WIP)
    1994 Toyota Camry- (sold)
    Nov 2005
    Anyone? Also I checked under the hood and theres a sticker that says "OBD-II compliant"
    Feb 2005
    West Valley City, Utah
    that would mean it has obd-II. Also, supposedly ford thunder birds and cougars didnt get obd-II until 96. I have only found one 94 with obd-II, all the rest were ecm-IV or later.
    Progress,.... that is what I keep forgetting ;)
    planning_[++++++++++]. 110%
    parts___[++++++----] around 60%
    install___[-----------] -9,000%
    Nov 2005
    Thanks! I guess I will try the OBD-II and see if it really does work and try to inegrate it into Road Runner. If it doesn't work out I might as well just return it.
    Thanks again.
  1. OBDII Signal Splitter (for Infiniti G35)
    By Caelric in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-14-2007, 09:32 PM
  2. 1994 Saab 900 & OBDII
    By Shark in forum General Hardware Discussion
    Last Post: 11-03-2003, 09:58 AM
