Results 11 to 20 of 24
Thread: Mitsubishi Lancer Evolution 4/5/6/7/8/9 EvoScan Project
  1. #11
    Oct 2006
    UK
    Very interested in this for my FTO. The lack of OBDII compliance is a complete pain. If I can lay my hands on a cable, I will certainly be registering/purchasing this.
  2. #12
    Dec 2006
    open port 1.3 is not working with my mitsubishi galant
  3. #13
    Jan 2007
    Quote Originally Posted by colombiano View Post
    Depends on what year you've got but most Mitsu vehicles need pins 1 & 4 to be shorted in order for it to be put in diag mode so the software will work
  4. #14
    Feb 2007
    Quote Originally Posted by CPhoenix View Post
    Hello!
    Is it helps for European Mitsubishi Galant, 1999 year?
    I try to use this tool, but it didn't detect ECU!
    Thanks!
  5. #15
    Feb 2006
    Ontario Canada
    any confirmed reports of this (or at least the cables) working with a 95 Eclipse (4G63T.. has OBDII) I know the posts above mentions it.. but just want to make sure the cable works before I buy it.. Software I am not too interested in, as its a little out of my budget right now
  6. #16
    Mar 2007
    95 Eclipse is NOT obd1
  7. #17
    Feb 2006
    Ontario Canada
    no one said it is...?
  8. #18
    Oct 2006
    UK
    I'm not sure how you ouput the data in your program, but is there anyway of designing a plugin to work with a custom Frontend.
    I use Centrafuse, which has a built in ODBII page. Assuming it pulls its data from a particular source, could EvoScan be set to output its data in a way that the ODBII tool would recognise. XML? (Obvioulsy some of the fields would be out, but MUTII is quite similar)
    Currently I have to minimise my frontend to use EvoScan, which is a bit fiddly to use on a touchscreen.
    Newbie BrianFerry's Avatar
    Sep 2007
    Russia, Moscow
    Hi,guys.
    Does EvoScan work with ELM327 Scantool.net Multi-protocol reader?
    Subaru Forester SG5 2.0 XT - 2002г
    Made in Japan, Made for Japan.
    http://board.forester-moscowclub.ru/...ead.php?t=2031
  10. #20
    Jan 2008
    evoscan
    Evoscan is a datalogging program. Are you looking for a program that will pull ses or check engine light codes on your car?
    I use a tactrix cable that connects my obd2 connector to my laptop. With it connected, I can flash my car (using ecuflash), log my car (using evoscan), and pull ses or service engine soon light codes using OBD Scantech. Link is posted below, but you'll need to register in order to download.
    http://www.aktivematrix.com/forum/dl...gory&cat_id=13
  1. Project FTPC - 1995 Mitsubishi FTO - U.K.
    By Vacheron in forum Show off your project
    Last Post: 01-16-2011, 03:21 PM
  2. Mitsubishi Outlander 2003 Project
    By angelito46 in forum Newbie
    Last Post: 05-23-2007, 09:05 AM
  3. Mitsubishi Super Lancer
    By Tweet in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-14-2006, 06:16 AM
  4. Mitsubishi Space Cargo project
    By canopy in forum Show off your project
    Last Post: 02-07-2006, 12:34 AM
  5. Lancer Evolution 8
    By titaniumkingpin in forum Show off your project
    Last Post: 12-24-2005, 03:52 PM
