there are several communication adpaters for truck that use the J1939 and J1708 data link here's a small list
1 - magikey(nexiq)
2 - noregon
3 - autotap
4 - kentmore
Aside from my Thunderbird, I'm also building a PC for my dad's RV. Unfortunately, it's pretty hard to find any information on how to tap in to the electronic control systems on the thing. It's a 2003 model, Freightliner frame, Cat 3126E engine, and an Allison 3000-series 6 speed automatic.
I know it can be tapped, because Camping World sells a standalone device which reads all sorts of data even including realtime torque output, but I'd prefer to have something that interfaces with a PC so I can customize the UI and log information.
Anyone have experience with these things? Are there any "universal" cables which I can use in the T-Bird and then pull out and plug in to the RV during trips?
I don't know what I'm doing anymore.
1 - magikey(nexiq)
2 - noregon
3 - autotap
4 - kentmore
I have loaded VMSpc (http://www.silverleafelectronics.com/?q=node/6) in my Rv and now I'm looking for a way to integrate it Streetdeck. Any ideas? I know I can run it as an external mod.
If your RV has a J1939 port, you should be able to run Au J1939 message center:
The following is a you-tube video:
http://www.youtube.com/watch?v=1kB3Cl31cZ0
Device image and PC screen cut for your reference:
One comment on diesels, since I happened to see this thread... at least with common-rail diesel (CRD) engines, which I know are a newer technology and may not be in a 2003, it's pretty much impossible to find out instantaneous fuel economy. So if that's of interest to you, you might as well forget it right now...
