Page 6 of 13 FirstFirst 12345678910111213 LastLast
Results 51 to 60 of 126
Thread: Links to Virtual Instrument Cluster projects?
  1. #51
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    not finished just were i left off.
    but i think it was a great start.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
  2. #52
    Newbie odog87's Avatar
    Jul 2005
    Alabama
    I don't post often but I would like to know if anything has happened on this project.
    I'm not much with programing but I'd personally like to have a 3D virtual dash for my project. That being said I have a game engine (Torque), that I believe could do this, but I could use a lot of help. Here is a sample of the style of my guages. Is there any one here interested in helping me?
    1997 Ford Expedition (a giant blank slate)
  3. #53
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Our new DashXL™ technology would work great for this project! To give you an idea of what your style of gauges would look like using DashXL™, I have created a dashboard that replicates your gauge (see below). If you're interested in using DashXL™ for this, I'd be happy to help you create your dashboard. Also, don't forget to check out our DashXL™ design contest. We're going to be giving away $350 in prize money to the winners!
    -Brian
    www.palmerperformance.com
    Brian @ Palmer Performance Engineering, Inc.
    http://www.palmerperformance.com
  4. #54
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Attached is the DashXL™ file for that gauge design if you'd like to open it in PCMSCAN™.
    Attached Files Attached Files
  5. #55
    Oct 2004
    NY
    I forgot about this thread... I mentioned my ideas for my instrament panel here before, well, I am now under contruction...
    I winded up going with a 6.3" toshiba panel..., screw 1/4 vga, this screen is full xga, 1024x768 this screen is what's used in the sony u1 & u3 japanese micro laptops, & the one I am using has been upgraded with a transflective enhancement... it's a 6 bit lvds interface...
    it's going in place of my speedometer, which will be suplimented by a factory hud from like a bonneville or a vette...
    this is the best design for me, & I will retain full instramentation regardless of this display, which is a bit different aproach than using it as sole instramentation...
    once the hardware is all in & running, I'll work the software end... I will be able to run this screen as an extended desktop from my primary pc, & I'll be able to switch it to several other things including the camera feeds & the secondary pc.... should be interesting & fun to play with...
    I need to buy some transparency printable sheets & a laminator to make my own gauge face for this, & relocate my high beam indicator & check engine light, but otherwise it fits like it was made for it.....
    my final push to do this was a new s550 that came into my shop... they use 3 main analog gauges at first glance, but the center one is a digital representation of an analogue gauge on an lcd, & of course, this gives the ability to overlay other information over the speedometer
    I came up with another idea that I am still half considering... of mounting my original speedometer in a small enclosure, & fixing & focusing a camera on it, back light it at night, & front light it during the day, so it matches the 2 analogue gauges, like benz did.. then use this as a background on this screen.... I could then overlay track info, pc info, next turn directions... man, there are a lot of possibilities....
  6. #56
    Oct 2004
    NY
    is there anyway with an obdII software, to use a photograph of a gauge, or I guess a high resolution image? where I could get a gauge to look exactly like my analogue gauges?.... that would be sweet...
  7. #57
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Quote Originally Posted by turbocad6 View Post
    Yes!! Our DashXL™ technology (which comes as part of our PCMSCAN™ OBD-II software) fully supports every aspect of this feature.
    Using DashXL™ you can take a picture of a gauge (or anything you want) and use it as the background for your gauge/dashboard. You can also use another picture/photograph as the needle for your gauge. DashXL™ will take care of rotating the image around the dial correctly.
    -Brian
  8. #58
    Oct 2004
    NY
    well, that sounds like exactly what I need... I bookmarked your site & I'll dig some & check it out... sure would beat having to do the camera/analogue thing
  9. #59
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Great!
    Also, if you do decide to make a dashboard, don't forget to enter it into our dashboard design contest!
    -Brian
  10. #60
    Jan 2007
    if you could use that without having obd2... that'd be ideal. i have an 89 supra, and no obd. :-(
  1. Replies: 39
    Last Post: 08-12-2007, 12:05 PM
  2. Communicating w/ VW Instrument Cluster MFD?
    By leonard in forum Newbie
    Last Post: 04-16-2006, 11:40 PM
