Results 1 to 2 of 2
Thread: Diesel OBD II
    Aug 2006
    Boring, OR
    Thumbs up Diesel OBD II
    I am wondering if any of the Diesel preformance companies make a program that will interface with a carpc. I know that BullyDog and Banks both make programs that work through PDA's that alow you to change your power levels and monitor aux inputs ie. EGT's, boost pressures, trans temps, these do not typicaly run through the common OBD II connectors. I am new to this carputer thing, and am just trying to decide what and how I want to build a system for my truck.. I am still deciding on weather I want to remove my factory stereo and go with just the computer program to run everything through amps or integrat it into my stock radio system.
    This looks like a great resource here I appreciate the forum.
    Scott
    _
    Mar 2004
    Little Elm, Texas
    moved to the appropriate forum.
    Jan Bennett
  1. Calculate HP base on OBD II data?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-20-2011, 02:08 PM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  3. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  4. Need Help - Yukon Denali HU w/ OBD II and camera
    By Anders in forum Input Devices
    Last Post: 03-04-2005, 12:44 PM
  5. Need Help - Yukon Denali HU w/ OBD II and camera
    By Anders in forum General Hardware Discussion
    Last Post: 03-04-2005, 08:38 AM
