Thought i should make a new tread as the old 'Skinnable OBD II Software' one is a little long and out dated. I stopped coding, and released partial code. I am a little short on time for the next few months. read the release 'readme' if you want to attempt to use what I have released.
SourceForge: http://sourceforge.net/projects/br3-obd2/
ETA: Unknown
Status: Stopped Coding for a while.
Code Sections:
Find BR3: Done (Test did not go right)
Determine Protocol: Done (Ford confirmed others untested, Read a couple posts down)
Send OBDII Requests: Done
Recieve OBDII Response: Done
Proccess OBDII Data: Done
ActiveX: Haven't Started Yet
GUI/Skin stuff: Currently Working On
Trouble Code Lookup Tables: Done
Extended OBD Data Support: Will be partially supported (You must supply the PIDs, unless someone can give me a list of them)
This project will be a working example and activex.
If someone can provide me with a layout for a skin (gauge locations etc.) I will make it skinnable too.
Any other suggestions or add-ons any one wants?
Draxx: The Mongoose interfaces currently don't support ford (my parts truck). also the reason many of the people on the other tread wanted the br-3 was because it was cheap ($38-$96) and once one person saw it the reast kinda jumped on the bandwagon. If they had it for ford and I knew about it before I sold my mustang (the car with the carpc); I probably would have gotten it instead (since it included code). so, no I'm going to stick with the br-3, and work on it by my self. (I did find a nice pdf on that site that has a tutorial on 'C', now I can learn that too, thanks).
Enforcer: The RoadRunner looks like it might be helpful in making the skinnable part, I will look at it (I just downloaded binary and source for it) when I get to that point.
Mongoose Ford comes out at the end of this month. All you had to do is ask.![]()
I need a little help from some one who's car supports one of the following OBDII protocols:
VPW (GM)
ISO-9141 (Asian)
ISO-14230
ISO-14230 Fast Init
I need to find out how to initilize the interface for these protocols. If you have one of these please follow the following instructions and get back to me. I would prefer if you use Diagnose 3.2 but 4.0 might work.
1) Download Portmon (http://www.sysinternals.com/Utilities/Portmon.html) this will log all serial communications with the device.
2) Make sure 'Diagnose' is not running, untill I tell you to. Open Portmon.
3) In Portmon under the 'Capture' -> 'Ports' place a check next to all the com ports.
4) In Portmon under the 'Edit' open 'Filter/Highlight' and enter 'IRP_MJ_WRITE;IRP_MJ_READ' (no quotes) in the 'Include' box.
5) In Portmon under 'Capture' place a check next to 'Capture Events'.
6) Launch 'Diagnose'.
7) Click 'Start' button in 'Diagnose'.
8) Click 'Automatic Protocol' Button.
9) After 'Diagnose' finds and loads everything DON'T do anything in 'Diagnose' (no checking sensors and stuff).
10) Go to Portmon and wait for the window to stop scrolling (or 3 minutes which ever comes first).
11) Uncheck 'Capture Events' under 'Capture' menu.
12) 'File' 'Save As' and send me the file.
13) If you are feeling very generous (and have time) rerun steps 5-12 a little differently as mentioned below.
13*1) In Portmon 'Edit' -> 'Clear Display'
13*2) Redo steps 5-12 selecting the protocol manualy (not step 8).
Please include:
The Version of Diagnose
The Protocol that was used
The Make/Model of car
As I only have an old Ford F-150 I have no way of testing the other protocols besides bugging the neighbors. So if you want this to support other vehicles I will need informatio on the initilization. Thanks in advance!
The way the the whole OBDII thing works (as I understand) looks pretty simular interface to interface, so If you want to give a code example I might be able to build support for multiple interfaces into this one activex. as for making a front end for anything, I make some of the uglyest programs in existance so I would rather stick to the code, and let someone else make the front ends. or else if someone makes an image of a front end I can put code behind it. Maybe frodo might take the activex and put it in frodoplayer (less work for him).
The interface does sound nice though, but I really have no real need for one any more, no computer or ECU in my camaro.
I know this is an old thread, but I would like to add to it.
I have started to work on a small project using VB6 that communicates with the BR-3 unit, and can pull data into your programs.
I have this working on my 2004 Grand Prix GTP thus far, and would like to test later on with other vehicles.
I will post a simple sample application soon as I can make sure it is working, just wanted to let some others know, incase they want something like this.
