Results 1 to 4 of 4
Thread: Suggestion for 2006 Subaru Legacy
    Jan 2006
    Smile Suggestion for 2006 Subaru Legacy
    Hi Everyone,
    Finaly got my Carputer installed.
    Now need help for choosing OBD cables. I prefer USB connection since all the wiring has been done. However, I know some software is not support USB, please give me suggestion.
    Thanks.
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    For a Subaru, take a look around this site. You may want to read up on the differences in the Subaru Select Monitor (SSM) protocol as opposed to the OBDII protocol. It provides Subaru-specific parameters and can update at a much higher rate than generic OBDII. There is much free software out there for SSM for datalogging and downloading/flashing ROMs, but you need a special cable to use it. So if you want this kind of access to your ecu, then read up on those cables. The OpenPort and the Cobb Accessport cables work very nice.
    Jan 2006
    Thanks wi77iam,
    Still not sure which cable I should get.
    http://www.tactrix.com/ Should i get the $91.00 or the $79.00 one?
    Can you help me to confirm it works for 2006 Legacy and able to Flash ECU?
    Jun 2003
    Chester Springs, PA
    Quote Originally Posted by jackyyuen View Post
    Thanks wi77iam,
    You just need the $79 one. I can't confirm it will flash a Legacy since I have an STi. This link indicates that it will.
  1. subaru legacy mounting problems
    By DarkFox1 in forum Fabrication
    Last Post: 04-02-2007, 01:18 PM
  2. 2005 Subaru Legacy GT install
    By stage3legacy in forum Show off your project
    Last Post: 03-21-2007, 02:39 AM
  3. '05 Subaru Legacy and display enclosure
    By Flander in forum General MP3Car Discussion
    Last Post: 03-29-2006, 12:50 AM
  4. Subaru Legacy GT Limited – Install Complete
    By xcntrk75 in forum Show off your project
    Last Post: 03-09-2006, 02:32 PM
  5. Replies: 1
    Last Post: 01-10-2006, 05:00 PM
