ori files are the orignal manufacturer map on the ecu, mod is a tuned file galetto tool is only good for bmw and even then it sometimes goes wrong as after using it to write a file it does not close the ecu lol! hope that helps. if u try to mod maps urself without knowing what u are changing u will cause some damage to the engine because there are so many different maps on there like gear change, rev limit, ignition timing, air fuel ratio! also if u buy cheap maps from the internet u can kill the ecu.
LinkBack URL
About LinkBacks
