Results 1 to 5 of 5
Thread: Flashing your ECU
    Dec 2005
    Sydney
    Thumbs up Flashing your ECU
    Hi all,
    I noticed a few people asking about if there was anything that wasn't expensive that would allow you to flash your ECU. Then answer is Yes, its free!
    check out: http://www.openecu.org/index.php?title=Main_Page
    (no i'm not from openecu)
    I had some other links that included where to buy cheap connectors to hook up your carpc to your laptop but i cant find them at the moment. If anyone can find some please post.
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    openecu.org has free flashing software but it only works with Subaru and Mitsubishi.
    May 2006
    Seattleish, WA
    Quote Originally Posted by wi77iam View Post
    Plus... In general, not all ECUs are flashable.
    :: Mark
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    All good replies. Though on the subject of OpenECU, it's not quite free, or rather, you'll need a cable. I don't think it's a straight through. I believe there's some voltage conversion going on to get program the flash in addition to the USB serial port.
    I actually have a car that this applies to and I have the factory ecu reprogrammer, I wanted to use my cable as it's the same for the most part, but I couldn't get any details. (I can't just use the factory reprogrammer as I also need a DRBIII which is around $3000)
    When my schedule clears up, I'm getting the cable and will be working on some OS software for it.
    Regardless, if it applies to your car, $89 for a cable is a great friggin deal as you can use it for diagnostics as well. For instance, on OBDII, I get maybe 10samples a second, some of the guys are getting well over 200 a second using the cable and evoscan.
    Plus there are many more parameters to read then would normally be exposed via OBDII.
    FLAC FC3S's Avatar
    Jul 2006
    Seoul, Korea
    i flashed my ecu once..
    got slapped with indecent exposure..
    anyway, i wouldnt suggest anyone flashes their ecu, get someone qualified to do it, u dont wanna screw the ecu up +_+, then ur car dont work
  1. ECU Remapping
    By agrawal_nipun in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-06-2006, 08:58 PM
  2. Clip Definition in Skins and Flashing
    By RoyN in forum Road Runner
    Last Post: 06-18-2005, 09:25 PM
  3. Help me on Sagem SL 96 ECU
    By pashe007 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-26-2005, 06:55 AM
  4. ECU to Car PC problem.
    By cas850 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-23-2004, 02:15 AM
  5. ECU Programming/Tuning
    By swzine in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2003, 08:55 AM
