Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: MPG Computer for 94 GM ALDL
  1. #11
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    my 95 C4 corvette had the display. as did my brother and his wifes C4's. i believe it was a late 80's early 90's cutlass with the FE3 computer system that would also tell you this info. i am looking heavily into this as i want a mpg display for my 87 fiero gt.
    ha!, a two year bump :P
  2. #12
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    This has seemed to be fairly accuarate:
    MPH / (RPM * Inj Pulse Width * Inj Constant * 0.000212)
    Inj Constant is the rating of your injectors in lbs/hr
    The pulse width can be retrieved via most GM ALDL interfaces, same with mph and rpm.
    You HAVE to average this over say, 2-3 minutes because it jumps around alot depending on if you have the car floored or no throttle at all.
    This is only valid for a car with 8 injectors, and I believe only for batch fire cars as that would change the 0.0000212 constant otherwise.
  3. #13
    Apr 2007
    Edmond, Ok
    hmm, sounds hard to figure out for a v6. especially in my case. i have a 87 fiero gt with the 06 malibu 3500 and the 122730 ecm conversion from a 88 beretta. so digging up all the correct info will be very tough.
  4. #14
    Newbie Wagonmaster's Avatar
    Mar 2007
    Camas, Washington (near Portland Oregon)
    Old thread but I was searching around...........
    EBL Flash from DYNAMICEFI.COM will do this for you. I use it for my TBI Caprice and I highly recommend it.
    I also have a GranPrix center console and DIC I could sell. I pulled it out a while back to install a Riviera console. I think the DIC calculates MPG based on the VSS signal and the float level in the tank but don't quote me At the very least it has a cool rotating compass!
    Russ
    '93 Caprice Classic "Woody"
    SP13000
    TM-868
    Roadrider
    XM PCR, Usb Radio, WIFI, GPS, PCTV HD and 3G via tether
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 09:51 AM
  2. Cutting power to USB after computer has shutdown
    By lookinco in forum Power Supplies
    Last Post: 05-17-2006, 01:05 PM
  3. Computer becomes unresponsive, inverter problem?
    By tsb4k in forum Power Supplies
    Last Post: 10-23-2005, 02:22 PM
  4. computer theft tracking - PC PhoneHome
    By Question in forum General MP3Car Discussion
    Last Post: 07-16-2003, 02:14 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
