Excuse the blur.
Can you please determine the protocol used in my car. I read somewhere that pin 4&5 are must. But I don't have pin5. Also there are total 7 pins. Car is Hyundai.
Thanks in advance
Regards,
AG
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
It is Hyundai Santro 2003 Asian Model.
AG
It seams you have ISO 9141 on your vehicle for OBDII
Starting from PIN 1 from Left to Right, Top to Bottom. The top left most pin is Pin 1 and the pin directly below it is PIN 9.
1 Discretionary* (GMLAN SW CAN Line) SW CAN
2 + line of SAE J1850 J1850 VPW or J1850 PWM
3 Discretionary* (GMLAN MS CAN H) MS CAN
4 Chassis Ground.
5 Signal Ground PWR GND 13
6 Discretionary* (GMLAN HS CAN H) HS CAN
7 K Line of ISO 9141-2 ISO K
8 Discretionary*
9 Discretionary* (GM ALDL)
10 - line of SAE J1850 J1850 PWM L
11 Discretionary* (GMLAN MS CAN L) MS CAN
12 Discretionary*
13 Discretionary*
14 Discretionary* (GMLAN HS CAN L) HS CAN
15 L line of ISO 9141-2 ISO
16 Un-switched Vehicle Battery Positive VBATT
Thanks chewwtoy.
Will ElmScan5 and allinone work this?
AG
chewwtoy, please.. can you tell me what you think about this:
http://www.mp3car.com/vbulletin/show...d=1#post979582
