Results 1 to 7 of 7
Thread: ebd 2 to car computer
    Newbie norwegianguy's Avatar
    Sep 2006
    norway
    i know... i mean obd 2 in the title
    hi.. new to this forum, just wondered if it is possible to connect my car obd 2 port to my in car computer, and have it display stuff like rpm and engine temp on the computer display? and if so, how and where to get the necessary parts and wires,
    Chrysler stratus 2.0 Le
    Pentium 2 MHz (soon to be updated)
    300 GB hdd
    7" touch display
    120w surround amplifier
    Newbie Montanya's Avatar
    Aug 2006
    Ok I know I am a noob here but I had to post it...
    Sep 2006
    norway
    kjefta di
    i have tried to search for a software and cable but i can only find those tools that connects to the obd 2 port, looking for a software and cable that allows me to display readouts from the engine directly onto the display as i am driving, if it is possible
    Jul 2006
    If you want a ready-made display, try ScanGauge. It hooks up to the OBD Port and gives you the readings you need.
    Do you want to build your own instrument display? Or do you have a touchscreen display in your central dash area and you want get data from the engine to display there?
    If you want to make your own gauges/instrument cluster, you're on your own, at least for now. Only a few people have tackled this and so there are no solutions already out there.
    If you want to display data in your entertainment display, several folks have created plug-ins, etc. for the "front end" software that runs those things. This should be fairly easy for you to add. Check out the threads on adding OBD-II to front end displays/software.
    If this doesn't meet your needs and you really want to roll your own, you will need to do quite a few things. First, you'll need some sort of hardware interface. This will communicate with the vehicle and then make that data available to the PC. One of the best articles I've seen on doing this is linked in this thread:
    http://www.circuitcellar.com/adverti...ghtner-183.pdf
    There are lots of other choices as well. Check out any of the sites that offer software-based SCAN TOOLS. You can get the hardware and specs to write your own software to read the data.
    Once you have all this figured out, you can then integrate the data into your application to display what you want.
    As you can see, no easy solutions. It's a lot of work!! HTH. . .
    Sep 2006
    norway
    found out that it is obd 1
    found out its obd 1, not obd 2, just want it to display rpm, engine temp and general errormessages on my onboard computer display
    i am still looking for cables that allowes me to connect the obd 1 to either the com or usb connector on the computer, also, would be nice to get reccomandation on software to use
    it doesnt bother me that its a lot to do, gives me something to do when i got time to spare
    Jun 2003
    OBD 1 Cables
    Check this site:
    http://www.aldlcable.com/
    Thanks, audioforge
    Sep 2006
    norway
    ok,
    thanx, audioforge, just the thing i was looking for,
  1. computer in car
    By Nuclei2v5x in forum Newbie
    Last Post: 05-19-2009, 10:00 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  3. Starting the computer as you approach the car
    By Mxyzpltk in forum General Hardware Discussion
    Last Post: 12-28-2005, 02:14 AM
  4. Car computer vs regular head unit
    By dlewis187 in forum General MP3Car Discussion
    Last Post: 12-11-2005, 01:31 AM
  5. Ultimate Car Computer Vehicle
    By Pegasus in forum General MP3Car Discussion
    Last Post: 01-21-2005, 05:26 AM
