You'd be better off looking at an Opel-specific site or picking up a shop manual for that vehicle.
These forums are foussed on discussion of PCs in vehicles, not the computers that control engine management.
Hello all.
I'm a newbe, and I own a '98 Opel Tigra. Anyone knows what kind of ECU does it have?
Thanks everyone!
it's not OBD-II, you need a gm tech2 to scan it
2001 Passat 130TDi Sport - Via Epia 15000, 1gb, 100gb, 220w psu, 7" lilliput motorized touch (chopped and in dash as a fixed), bluetooth, bu-303 gps, 7 port usb hub, tiny keyboard, netgear 54mb wifi, optima yellow top, ryder rt1170x, freecom dvb
Thanks, altough this was not what I wanted to hear...![]()
Anyway, does anyone know if there is some open source project aimed at getting some data from my ECU?!? BTW, there is no way I'll get M$ Windowson my Tigra
Thanks!
sorry for bringing this old topic alive again. But I also have an Opel Tigra and I wonder if there's any update on this. Planning to do live data on my carputer, but the car surelly isn't OBD2. Maybe ALDL.
Anyone was able to read the data without the Tech II (the most expensive automotive scanner I've seen)
[]s
You'll probably get more information from the forum at Migweb:
Clicky
Sorry for the blatent plug, but you need to take a look at our Vauxhall/Opel specific tool this covers the Tigra.
Gareth
UKOBD
i'have an opel tigra 1999. if you have a 16pin connector it could be ain iso9141 protocol... injection system is a multec (S on older veicle, MPi on new).
To read this data it's possible that ELM 323 could work.
your obd connector are needed pins 3-4-5-6-7-12-16.
I will buy an interface based on elm323... i will wrote the results
