Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: OBD II Missing Pin 5 in DLC
    Oct 2005
    Hi All,
    Bought ElmScan scan tool and maybe did not do enough homework and found that my car, Toyota Wish JDM (Missing Pin 5 in DLC) is incompatible. Did a bit of searching and found that Pin 5 is actually the signal ground. Any idea where I can find this signal ground so that I can tap to it?
    Thanks in advance for any help rendered :-)
    dragonz
    Aug 2006
    Pakistan
    Looks like we both have same problem. Check this;
    Which protocol is this?
    Gip
    Gip is offline
    Jan 2005
    Just use pin 4, they are the same (they are usually tied together anyway..)
    Oct 2005
    Quote Originally Posted by Gip View Post
    Hi Gip, correct me if I'm wrong. If i short these 2 pins together, it might work? Hmm... will give it a try
    Aug 2006
    Pakistan
    Hi dragonz,
    Let me know if it works for you. I am also interested in buying ElmScan.
    AG
    Gip
    Gip is offline
    Jan 2005
    pin 4 and pin 5 are "virtually" the same. in the car connector, they are usually connected together. just try... but only if you have good manual skills! connecting as i described won't damage anything, but if you mess out something you can seriously damage your car/the scanner... so do at your own risk!
    Oct 2005
    Hi Gip,
    I tried and got a signal and boy was I happy . But my happiness was shortlived as I'm using digimoto ver 4.02 and the serial error message was "BUS Error". So i don't know if the software was the culprit.
    But guess what, that was not the end of it coz i left the connection as it is when i shut down the engine. To my horror , the engine refused to start after repeated tries. So I unplugged the OBDII connector and the enging sprung to life
    After Digimoto 5 is released, maybe I would try again but chance is that I will go to a tuner garage and check with them if the "connection" is valid but this would mean at my next servicing in about 2 months time. Meanwhile I will wait for the release 5.
    Aghazi bro, guess u have to wait then...
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Doesn't the placement of the pins signify the protocol that is being used? And thus, if your pin placement is different on the OBD connector than it is on the OBD reader you bought, wouldn't it be safe to assume that the protocol may be different as well? If the protocol is different, then swapping a couple of pins to make a connection won't help... and judging by the "BUS Error" you are seeing, it seems the reader may be for a different protocol...
    The fact that your engine wouldn't start with the reader plugged in is another big clue... having the pins different in the connectors between two different protocols prevents you from making connections that shouldn't be made, when you plug in the wrong type of reader. Just hope you didn't damage anything in the process...
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Gip
    Gip is offline
    Jan 2005
    well, since all the pins of a specific protocol are in there, the protocol should be implemented.. using the protocol-dedicated pins for a different purpose would be a violation of the standard...
    Oct 2005
    UK
    The various pin layouts are shown here. It is important to remember that the presence of the socket (even with pins) does not necessarily indicated OBD2 compliance. The age of the vehicle has a significant amount to do with it i.e. 1996 on US, 2001 on Europe (2004 on for diesel).
    Hope this helps,
    Gareth
  1. Calculate HP base on OBD II data?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-20-2011, 02:08 PM
  2. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  3. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  4. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 12-16-2006, 12:21 PM
  5. Where went the Guages in the OBD II plugin?
    By bns2000 in forum Centrafuse
    Last Post: 08-11-2006, 11:39 PM
