Page 18 of 18 FirstFirst ... 89101112131415161718
Results 171 to 179 of 179
Thread: New OBDII scantool - Beta testers?
  1. #171
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by Spyder View Post
    Well after reading 12 pages of comments I have to say this looks like a great piece of harware. Are there any thoughts on making a bluetooth version? Any development in making these not have to use the old modem commands? In post #110 you mention these are now in "limited production" I assume by the website you are still producing them? I have an 03 Accord V6 and would definatly like to purchase one IF they are available and IF someone can point me to how it would be used in a RR front end.
    Thanks in advance!
    PS how much should I over pay for an additional OBD cable? I would like to have a spare.
    Hi Spyder,
    Yes we are in full production mode now. Have not given much thought to making a Bluetooth version as people seem to have all sorts of problems with bluetooth, but we are looking at moving away from AT commands and finally releasing a binary version.
    One of the free programs that ships with the tool can be embedded in RR. See this thread
    Launch OBD program inside RR
    Extra staright cable is $ 7.50 / cable, just mention in your comment that you need an extra cable and will set you up with one...
    Paul
    www.obdpros.com
  2. #172
    Apr 2006
    Sydney, Australia
    @michbound - - Hope this helps with Subaru Support - got this info from open ecu forums and enginuity etc.
    The subaru select monitor protocol uses an ISO9141 interface and uses UART settings: 4800 bps n, 8, 1 all data is sent and recieved using small packets that all share a common header.
    packets all follow this structure:
    0x80
    Destination byte
    Source byte
    Data Size byte
    data...
    Checksum byte
    known Source and Destination bytes:
    0x10 Subaru ECU
    0xf0 Diagnostic tool
    the Data Size byte specifies the number of data bytes in the packet the Checksum byte is the 8 least significant bits of the sum of every packet byte (including the header)
    for example:
    if you send the packet:
    0x80 0x10 0xF0 0x01 0xBF 0x40
    the ecu might respond with:
    0x80 0xF0 0x10 0x39 0xFF 0xA2 0x10 0x0F 0x1B 0x14 0x40 0x05 0x05 0x73 0xFA
    0xEB
    0x80 0x2B 0xC1 0x02 0xAA 0x00 0x10 0x00 0x60 0xCE 0x54 0xF8 0xB0 0x60 0x00
    0x00
    0xE0 0x00 0x00 0x00 0x00 0x00 0xDC 0x00 0x00 0x55 0x10 0x00 0x00 0x02 0x00
    0x00
    0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F
    When sending a packet to the ECU the first data byte is the command byte.
    These are the known commands:
    0xA0 Read memory
    0xA8 Read single address
    0xB0 Write memory
    0xB8 Write single address
    0xBF ECU init
    -------------------------------- Command Formats --------------------------------
    A0 Block Read Request
    A0 PP AA AA AA CC
    PP == pad?
    AA AA AA = address
    CC == byte count - 1
    A8 Address Read Request
    A8 PP A1 A1 A1 A2 A2 A2 A3 A3 A3...
    PP == pad?
    A1 A1 A1 == address
    A2 A2 A2 ... == optional addresses
    B0 Write Block Request
    B0 AA AA AA DD DD DD DD DD ...
    AA AA AA == address
    DD DD ... == data of desired length
    B8 Address Write Request
    B8 AA AA AA DD
    AA AA AA == address
    DD == data byte
    BF ECU Init Request
    BF
    -------------------------------- Command Examples -------------------------------
    Block Read: Read 128 bytes from address 0x200000 (ecu returned all zeros)
    Sent:
    0x80 0x10 0xF0 0x06 0xA0 0x00 0x20 0x00 0x00 0x7F 0xC5
    Received:
    0x80 0xF0 0x10 0x81 0xE0
    0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0x00
    0xE1
    Address Read: Read Address 0x000008 and 0x00001C (ecu returns values 0x7D and 0xB1)
    Sent:
    0x80 0x10 0xF0 0x08 0xA8 0x00 0x00 0x00 0x08 0x00 0x00 0x1C 0x54
    Received:
    0x80 0xF0 0x10 0x03 0xE8 0x7D 0xB1 0x99
    Block Write: Write 4 bytes to address 0x200000 (ecu returns written data)
    Sent:
    0x80 0x10 0xF0 0x08 0xB0 0x20 0x00 0x00 0x01 0x02 0x03 0x04 0x62
    Received:
    0x80 0xF0 0x10 0x05 0xF0 0x01 0x02 0x03 0x04 0x7F
    Write single address: Write value 0x02 to address 0x00006F
    Sent:
    0x80 0x10 0xF0 0x05 0xB8 0x00 0x00 0x6F 0x02 0xAE
    Received:
    0x80 0xF0 0x10 0x02 0xF8 0x02 0x7C
    Certain bytes in the ECU Init string (returned from request 0xBF) can be examined to determine which parameters the ECU will support. The individual bits are flags that will be set to one if the parameter can be read from the ECU
    (byte 9 is immediately after the 5 byte ECU ID value)
    ********** BYTE 9 **********
    7 Engine Load
    6 Coolant Temperature
    5 Air/Fuel Correction #1
    4 Air/Fuel Learning #1
    3 Air/Fuel Correction #2
    2 Air/Fuel Learning #2
    1 Manifold Absolute Pressure
    0 Engine Speed
    ********** BYTE 10 *********
    7 Vehicle Speed
    6 Ignition Timing
    5 Intake Air Temperature
    4 Mass Air Flow
    3 Throttle Opening Angle
    2 Front O2 Sensor #1
    1 Rear O2 Sensor
    0 Front O2 Sensor #2
    ********** BYTE 11 *********
    7 Battery Voltage
    6 Air Flow Sensor Voltage
    5 Throttle Sensor Voltage
    4 Differential Pressure Sensor Voltage
    3 Fuel Injection #1 Pulse Width
    2 Fuel Injection #2 Pulse Width
    1 Knock Correction
    0 Atmospheric Pressure
    ********** BYTE 12 **********
    7 Manifold Relative Pressure
    6 Pressure Differential Sensor
    5 Fuel Tank Pressure
    4 CO Adjustment
    3 Learned Ignition Timing
    2 Accelerator Opening Angle
    1 Fuel Temperature
    0 Front O2 Heater #1
    ********** BYTE 13 *********
    7 Rear O2 Heater Current
    6 Front O2 Heater #2
    5 Fuel Level
    4 -------------------------
    3 Primary Wastegate Duty Cycle
    2 Secondary Wastegate Duty Cycle
    1 CPC Valve Duty Ratio
    0 Tumble Valve Position Sensor Right
    ********** BYTE 14 *********
    7 Tumble Valve Position Sensor Left
    6 Idle Speed Control Valve Duty Ratio
    5 Air/Fuel Lean Correction
    4 Air/Fuel Heater Duty
    3 Idle Speed Control Valve Step
    2 Number of Ex. Gas Recirc Steps
    1 Alternator Duty
    0 Fuel Pump Duty
    ********** BYTE 15 *********
    7 VVT Advance Angle Right
    6 VVT Advance Angle Left
    5 OCV Duty Right
    4 OCV Duty Left
    3 OCV Current Right
    2 OCV Current Left
    1 Air/Fuel Sensor #1 Current
    0 Air/Fuel Sensor #2 Current
    ********** BYTE 16 **********
    7 Air/Fuel Sensor #1 Resistance
    6 Air/Fuel Sensor #2 Resistance
    5 Air/Fuel Sensor #1
    4 Air/Fuel Sensor #2
    3 Air/Fuel Correction #3
    2 Air/Fuel Learning #3
    1 Rear O2 Heater Voltage
    0 Air/Fuel Adjustment Voltage
    ********** BYTE 17 **********
    7 -------------------------
    6 -------------------------
    5 Gear Position
    3 -------------------------
    2 -------------------------
    1 -------------------------
    0 -------------------------
    ********** BYTE 18 **********
    5 -------------------------
    4 Air/Fuel Sensor #1 Heater Current
    3 Air/Fuel Sensor #2 Heater Current
    ********** BYTE 19 **********
    ********** BYTE 20 **********
    6 AT Vehicle ID
    5 Test Mode Connector
    4 Read Memory Connector
    ********** BYTE 21 **********
    7 Neutral Position Switch
    6 Idle Switch
    4 Intercooler AutoWash Switch
    3 Ignition Switch
    2 Power Steering Switch
    1 Air Conditioning Switch
    ********** BYTE 22 **********
    7 Handle Switchv
    6 Starter Switch
    5 Front O2 Rich Signal
    4 Rear O2 Rich Signal
    3 Front O2 #2 Rich Signal
    2 Knock Signal 1
    1 Knock Signal 2
    0 Electrical Load Signal
    ********** BYTE 23 **********
    7 Crank Position Sensor
    6 Cam Position Senso
    5 Defogger Switch
    4 Blower Switch
    3 Interior Light Switch
    2 Wiper Switch
    1 Air-Con Lock Signal
    0 Air-Con Mid Pressure Switch
    ********** BYTE 24 **********
    7 Air-Con Compressor Signal
    6 Radiator Fan Relay #3
    5 Radiator Fan Relay #1
    4 Radiator Fan Relay #2
    3 Fuel Pump Relay
    2 Intercooler Auto-Wash Relay
    1 CPC Solenoid Valve
    0 Blow-By Leak Connector
    ********** BYTE 25 **********
    7 PCV Solenoid Valve
    6 TGV Output
    5 TGV Drive
    4 Variable Intake Air Solenoid
    3 Pressure Sources Change
    2 Vent Solenoid Valve
    1 P/S Solenoid Valve
    0 Assist Air Solenoid Valve
    ********** BYTE 26 **********
    7 Tank Sensor Control Valve
    6 Relief Valve Solenoid 1
    5 Relief Valve Solenoid 2
    4 TCS Relief Valve Solenoid
    3 Ex. Gas Positive Pressure
    2 Ex. Gas Negative Pressure
    1 Intake Air Solenoid
    0 Muffler Control
    ********** BYTE 27 **********
    3 Retard Signal from AT
    2 Fuel Cut Signal from AT
    1 Ban of Torque Down
    0 Request Torque Down VDC
    ********** BYTE 28 **********
    7 Torque Control Signal #1
    6 Torque Control Signal #2
    5 Torque Permission Signal
    4 EAM signal
    3 AT coop. lock up signal
    2 AT coop. lean burn signal
    1 AT coop. rich spike signal
    0 AET Signal
    ********** BYTE 29 **********
    ********** BYTE 30 **********
    ********** BYTE 31 **********
    ********** BYTE 32 **********
    ********** BYTE 33 **********
    ********** BYTE 34 **********
    ********** BYTE 35 **********
    ********** BYTE 36 **********
    ********** BYTE 37 **********
    ********** BYTE 38 **********
    ********** BYTE 39 **********
    5 Throttle Motor Duty
    4 Throttle Motor Voltage
    ********** BYTE 40 **********
    ********** BYTE 41 **********
    7 Sub Throttle Sensor
    6 Main Throttle Sensor
    5 Sub Accelerator Sensor
    4 Main Accelerator Sensor
    3 Brake Booster Pressure
    2 Fuel Pressure (High)
    1 Exhaust Gas Temperature
    ********** BYTE 42 **********
    7 Cold Start Injector
    6 SCV Step
    5 Memorized Cruise Speed
    ********** BYTE 43 **********
    ********** BYTE 44 **********
    7 Exhaust VVT Advance Angle Right
    6 Exhaust VVT Advance Angle Left
    5 Exhaust OCV Duty Right
    4 Exhaust OCV Duty Left
    3 Exhaust OCV Current Right
    2 Exhaust OCV Current Left
    ********** BYTE 45 **********
    6 ETC Motor Relay
    ********** BYTE 46 **********
    7 Clutch Switch
    6 Stop Light Switch
    5 Set/Coast Switch
    4 Resume/Accelerate Switch
    3 Brake Switch
    1 Accelerator Switch
    ********** BYTE 47 **********
    ********** BYTE 48 **********
    ********** BYTE 49 **********
    ********** BYTE 50 **********
    ********** BYTE 51 **********
    ********** BYTE 52 **********
    ********** BYTE 53 **********
    ********** BYTE 54 **********
    ********** BYTE 55 **********
    ********** BYTE 56 **********
    7 Roughness Monitor Cylinder #1
    6 Roughness Monitor Cylinder #2
    5 Roughness Monitor Cylinder #3
    4 Roughness Monitor Cylinder #4
    Parameters are read by providing a 3 byte address for each parameter via command 0xA8 For example use address 0x000008 for Coolant temp and use addresses 0x00000E and 0x00000F for engine RPM
    Parameters ************************************************** ********
    - Engine Load ----------------------------------------------
    8 bit value
    P0x07 = low byte
    Multiply value by 100.0 and divide by 255 to get percent
    - Coolant Temperature --------------------------------------
    8 bit value
    P0x008 = low byte
    Subtract 40 from value to get Degrees C
    - Air/Fuel Correction #1 -----------------------------------
    8 bit value
    P0x009 = low byte
    Subtract 128 from value and divide by 1.28 to get percent
    - Air/Fuel Learning #1 -------------------------------------
    8 bit value
    P0x00A = low byte
    - Air/Fuel Correction #2 -----------------------------------
    8 bit value
    P0x00B = low byte
    - Air/Fuel Learning #2 -------------------------------------
    8 bit value
    P0x00C = low byte
    - Manifold Absolute Pressure -------------------------------
    8 bit value
    P0x0D = low byte
    Multiply value by 37.0 and divide by 255 to get psig
    - Engine Speed ---------------------------------------------
    16 bit value
    P0x0E = high byte
    P0x0F = low byte
    Divide value by 4 to get RPM
    - Vehicle Speed --------------------------------------------
    8 bit value
    P0x010 = low byte
    Value is in km/h
    - Ignition Timing ------------------------------------------
    8 bit balue P0x11 = low byte
    Subtract 128 from value and divide by 2 to get degrees
    - Intake Air Temperature -----------------------------------
    8 bit value
    P0x012 = low byte
    - Mass Air Flow --------------------------------------------
    16 bit value
    P0x13 = high byte
    P0x14 = low byte
    Divide value by 100.0 to get grams/s
    - Throttle Opening Angle -----------------------------------
    8 bit value
    P0x15 = low byte
    - Front O2 Sensor #1 ---------------------------------------
    16 bit value
    P0x016 = high byte
    P0x017 = low byte
    Multiply value by 0.005 to get voltage
    - Rear O2 Sensor -------------------------------------------
    16 bit value
    P0x018 = high byte
    P0x019 = low byte
    - Front O2 Sensor #2 ---------------------------------------
    16 bit value
    P0x01A = high byte
    P0x01B = low byte
    - Battery Voltage ------------------------------------------
    8 bit value
    P0x01C = low byte
    Multiply value by 0.08 to get volts
    - Air Flow Sensor Voltage ----------------------------------
    8 bit value
    P0x01D = low byte
    Multiply value by 0.02 to get volts
    - Throttle Sensor Voltage ----------------------------------
    8 bit value
    P0x01E = low byte
    - Differential Pressure Sensor Voltage ---------------------
    8 bit value
    P0x01F = low byte
    Multiply value by 0.02 to get Volts
    - Fuel Injection #1 Pulse Width ----------------------------
    8 bit value
    P0x20 = low byte
    Multiply value by 0.256 to get ms
    - Fuel Injection #2 Pulse Width ----------------------------
    8 bit value
    P0x21 = low byte
    - Knock Correction -----------------------------------------
    8 bit value
    P0x22 = low byte
    - Atmospheric Pressure -------------------------------------
    8 bit value
    P0x023 = low byte
    - Manifold Relative Pressure -------------------------------
    8 bit value
    P0x24 = low byte
    Subtract 128 from value, multiply by 37.0 and divide by 255 to get psig
    - Pressure Differential Sensor -----------------------------
    8 bit value
    P0x25 = low byte
    - Fuel Tank Pressure ---------------------------------------
    8 bit value
    P0x026 = low byte
    Subtract 128 from value and multiply by 0.0035 to get psig
    - CO Adjustment --------------------------------------------
    8 bit value
    P0x027 = low byte
    - Learned Ignition Timing ----------------------------------
    8 bit value
    P0x028 = low byte
    - Accelerator Opening Angle --------------------------------
    8 bit valuev P0x029 = low byte
    Divide value by 2.56 to get percent
    - Fuel Temperature -----------------------------------------
    8 bit value
    P0x02A = low byte
    - Front O2 Heater #1 ---------------------------------------
    8 bit value
    P0x02B = low byte
    Multiply value by 10.04 and divide by 256 to get Amps
    - Rear O2 Heater Current -----------------------------------
    8 bit value
    P0x02C = low byte
    - Front O2 Heater #2 ---------------------------------------
    8 bit value
    P0x02D = low byte
    - Fuel Level -----------------------------------------------
    8 bit value
    P0x02E = low byte
    - Primary Wastegate Duty Cycle -----------------------------
    8 bit value
    P0x30 = low byte
    - Secondary Wastegate Duty Cycle ---------------------------
    8 bit value
    P0x31 = low byte
    - CPC Valve Duty Ratio -------------------------------------
    8 bit value
    P0x032 = low byte
    Divide value by 2.55 to get percent
    - Tumble Valve Position Sensor Right -----------------------
    8 bit value
    P0x033 = low byte
    - Tumble Valve Position Sensor Left ------------------------
    8 bit value
    P0x034 = low byte
    - Idle Speed Control Valve Duty Ratio ----------------------
    8 bit value
    P0x035 = low byte
    Divide value by 2 to get percent
    - Air/Fuel Lean Correction ---------------------------------
    8 bit value
    P0x036 = low byte
    - Air/Fuel Heater Duty -------------------------------------
    8 bit value
    P0x037 = low byte
    - Idle Speed Control Valve Step ----------------------------
    8 bit value
    P0x038 = low byte
    Value is in steps
    - Number of Ex. Gas Recirc. Steps --------------------------
    8 bit value
    P0x039 = low byte
    Value is in steps
    - Alternator Duty ------------------------------------------
    8 bit value
    P0x03A = low byte
    Value is in percent
    - Fuel Pump Duty -------------------------------------------
    8 bit value
    P0x03B = low byte
    - Intake VVT Advance Angle Right ---------------------------
    8 bit value
    P0x03C = low byte
    Subtract 50 from value to get degrees
    - Intake VVT Advance Angle Left ---------------------------
    8 bit value
    P0x03D = low byte
    - Intake OCV Duty Right ------------------------------------
    8 bit value
    P0x03E = low byte
    - Intake OCV Duty Left -------------------------------------
    8 bit value
    P0x03F = low byte
    - Intake OCV Current Right ---------------------------------
    8 bit value
    P0x040 = low byte
    Multiply value by 32 to get mA
    - Intake OCV Current Left ----------------------------------
    8 bit value
    P0x041 = low byte
    - Air/Fuel Sensor #1 Current -------------------------------
    8 bit value
    P0x042 = low byte
    Subtract 128 from value and multiply by .125 to get mA
    - Air/Fuel Sensor #2 Current -------------------------------
    8 bit value
    P0x043 = low byte
    - Air/Fuel Sensor #1 Resistance ----------------------------
    8 bit value
    P0x044 = low byte
    Value is in ohms
    - Air/Fuel Sensor #2 Resistance ----------------------------
    8 bit value
    P0x045 = low byte
    Value is in ohms
    - Air/Fuel Sensor #1 ---------------------------------------
    8 bit value
    P0x46 = low byte
    Divide value by 128.0 to get Lambda
    - Air/Fuel Sensor #2 ---------------------------------------
    8 bit value
    P0x47 = low byte
    - Gear Position --------------------------------------------
    8 bit value
    P0x04A = low byte
    Add 1 to value to get gear
    - A/F Sensor #1 Heater Current -----------------------------
    8 bit value
    P0x053 = low byte
    Divide value by 10 to get Amps
    - A/F Sensor #2 Heater Current -----------------------------
    8 bit value
    P0x054 = low byte
    - Roughness Monitor Cylinder #1 ----------------------------
    8 bit value
    P0x0CE = low byte
    Value is in ?
    - Roughness Monitor Cylinder #2 ----------------------------
    8 bit value
    P0x0CF = low byte
    Value is in ?
    - Air/Fuel Correction #3 -----------------------------------
    8 bit value
    P0x0D0 = low byte
    - Air/Fuel Learning #3 -------------------------------------
    8 bit value
    P0x0D1 = low byte
    - Rear O2 Heater Voltage -----------------------------------
    8 bit value
    P0x0D2 = low byte
    - Air/Fuel Adjustment Voltage ------------------------------
    8 bit value
    P0x0D3 = low byte
    Multiply value by 0.02 to get voltage
    - Roughness Monitor Cylinder #3 ----------------------------
    8 bit value
    P0x0D8 = low byte
    Value is in ?
    - Roughness Monitor Cylinder #4 ----------------------------
    8 bit value
    P0x0D9 = low byte
    Value is in ?
    - Throttle Motor Duty --------------------------------------
    8 bit value
    P0x0fa = low byte
    - Throttle Motor Voltage -----------------------------------
    8 bit value
    P0x0FB = low byte
    - Sub Throttle Sensor --------------------------------------
    8 bit value
    P0x100 = low byte
    - Main Throttle Sensor -------------------------------------
    8 bit value
    P0x101 = low byte
    - Sub Accelerator Sensor -----------------------------------
    8 bit value
    P0x102 = low byte
    - Main Accelerator Sensor ----------------------------------
    8 bit value
    P0x103 = low byte
    - Brake Booster Pressure -----------------------------------
    8 bit value
    P0x104 = low byte
    - Fuel Pressure (High) -------------------------------------
    8 bit value
    P0x105 = low byte
    Multiply value by 0.04 to get MPa
    - Exhaust Gas Temperature ----------------------------------
    8 bit value
    P0x106 = low byte
    Add 40 to value and multiply by 5 to get Degrees C
    - Cold Start Injector --------------------------------------
    8 bit value
    P0x108 = low byte
    Multiply value by .256 to get ms
    - SCV Step -------------------------------------------------
    8 bit value
    P0x109 = low byte
    Value is in Steps
    - Memorised Cruise Speed -----------------------------------
    8 bit value
    P0x10a = low byte
    Value is in km/h
    - Exhaust VVT Advance Angle Right --------------------------
    8 bit value
    P0x118 = low byte
    - Exhaust VVT Advance Angle Left ---------------------------
    8 bit value
    P0x119 = low byte
    - Exhaust OCV Duty Right -----------------------------------
    8 bit value
    P0x11A = low byte
    - Exhaust OCV Duty Left ------------------------------------
    8 bit value
    P0x11B = low byte
    - Exhaust OCV Current Right --------------------------------
    8 bit value
    P0x11C = low byte
    - Exhaust OCV Current Left ---------------------------------
    8 bit value
    P0x11D = low byte
    Switches are read in the same way a parameter is read except that it will
    return up to
    8 individual ON/OFF flags in the individual bits of the return byte
    Switches ************************************************** ************
    Switch P0x061
    6 AT Vehicle ID
    Switch P0x062
    6 Idle Switch
    3 Ignition Switch
    Switch P0x063
    7 Handle Switch
    6 Starter Switch
    2 Knock Signal 1
    1 Knock Signal 2
    Switch P0x064
    6 Cam Position Sensor
    5 Defogger Switch
    4 Blower Switch
    2 Wiper Switch
    Switch P0x065
    3 Fuel Pump Relay
    Switch P0x066
    6 TGV Output
    5 TGV Drive
    Switch P0x067
    0 Muffler Control
    Switch P0x068
    Switch P0x069
    4 EAM Signal
    0 AET Signal
    Switch P0x120
    6 ETC Motor Relay
    Switch P0x121
    7 Clutch Switch
    6 Stop Light Switch
    5 Set/Coast Switch
    4 Rsume/Accelerate Switch
    3 Brake Switch
    New Car PC Build list in progress
  3. #173
    VENDOR - OBDPros
    Mar 2006
    Kosti,
    Thanks for the detailed info, looks like just changing the baud rate on the ISO protocol should allow experimenting with the SSM protocol, I will work on adding that capability.
    Paul
    www.obdpros.com
  4. #174
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    @michbound
    Has there been any progress on SSM support? I'm really looking for the faster speeds of the SSM protocol over that of the standard ISO in the Subaru's and would love to continue to use the OBDPro's interface. Is the purchase of an updated PIC an option down the track to update it or are we able to update the firmware via usb?
    I installed my carpc into my pet Kangaroo, mate.
  5. #175
    Jul 2009
    Squamish, BC
    If obdpro supports the CAN protocol you can use that to read/log using the SSM addresses.
    CAN Baud rate on the OBDII connector is 500kb
    canid 7E0
    dlc 0x05
    service 0xA8
    padding 0x00
    3byte SSM address
    padding 0x0000
    I'm using the A8 service over CAN on my 09STI and it's fast. I log 20-30 parameters 4 times per second (including the broadcast CAN decoding). These images give you some idea of the complexity being logged. for example, fuel level has to adjust for movement in the tank, g-forces etc. and fuel range is based on average consumption over a recent period (not instant).
    The empty gauge in the first picture is the gear indicator (not shown when the car is not running).
  6. #176
    Oct 2010
    not sure if your still willing to sell these. i didnt read all all 12 pages but i am interested in one as well. i have an ultraguage but looking for something different and saw this. i have a 2010 kia forte koup sx 6spd. just message me if your willing to still do this
  7. #177
    Apr 2006
    Sydney, Australia
    Quote Originally Posted by Petrie View Post
    canid 7E0
    dlc 0x05
    service 0xA8
    padding 0x00
    3byte SSM address
    padding 0x0000
    This looks great, what did u use for this skin, is this custom and or would you release?
    Cheers
    Kosti
  8. #178
    Jul 2009
    Squamish, BC
    It is a custom Centrefuse plugin which means it is essentially a Windows panel.
    It's not ready to go yet. Still running on a laptop and I have to decide hardware and then deal with any hibernation/power issues. Unfortunately cost is getting in the way of building the hardware so it's going slow.
  9. #179
    Low Bitrate SierraStroker's Avatar
    Nov 2012
    Got a beastly 4x4 7.3L powerstroke turbo diesel I need a obdII scanner for. PM me.
  1. BETA testers needed for StreetDeck Europe
    By god_of_cpu in forum StreetDeck
    Last Post: 05-27-2008, 03:02 PM
  2. New frontend needs beta testers
    By GoatMaster in forum Other Cool Front Ends
    Last Post: 03-10-2006, 05:39 PM
  3. Windows Mobile Smartphone Beta testers needed
    By zorro in forum PhoneControl
    Last Post: 02-23-2006, 08:57 AM
  4. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  5. X-MP3Pad is out! I need beta testers!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 07-15-2002, 03:33 PM
