Page 4 of 18 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 178
Thread: New OBDII scantool - Beta testers?
  1. #31
    Newbie Borisimo's Avatar
    Mar 2006
    Tampa, FL
    Also paid, can't wait to test it out !
    2006 Scion tC
    Completion Status: [||||||||||]
    VIA M10K,1GB RAM, 60GB HD, DVD/CDRW
    DWW-700H VGA
  2. #32
    Low Bitrate Hopperhawk's Avatar
    Nov 2004
    USA
    Signed up and E-mailed.
    Centrafuse 3.1
    Garmin Mobile PC
    GPS, OBDII, Lilliput 629GL, Nightvision integrated video,
    Other fun stuff in works.
  3. #33
    Oct 2005
    Registered, and emailed. The product looks very interesting. One question though, with the Mobydic you had to constantly reset the power on it to keep it functional between boot ups (i.e. it could not remain connected in between boots, had to do a manual disconnection of the device). Will this device have the same problem?
  4. #34
    Apr 2006
    Quote Originally Posted by canadiandream View Post
    I have this same question. And also, it is $55 for the usb version shown on the website, right?
  5. #35
    VENDOR - OBDPros
    Mar 2006
    Not sure I understand, do you mean boot up of the PC? If you disconnect the PC from the OBDPro interface but leave the interface plugged into the DLC (car connector) and reconnect the PC that will be fine and will not require you to disconnec the OBDPro interface from the DLC.
    Let me know if this does not answer your question.
    Paul
  6. #36
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by black06stang View Post
    That was a question that came up amongst some other users and I apologize for not making it clear, no the $ 55 is for the serial version. If you want to test the USB it would be $70.00
    There is really no difference in functionality you also do not get a speed increase as compared to the serial since the microcontroller still communicates serially with the USB chip. of course if your laptop does not have a serial port you need the USB version.
    Paul
  7. #37
    Oct 2005
    So the issue has been that you have had to disconnect the OBDPro interface from the computer everytime you reboot.
    Ideally what everyone wants is where you plug one end into the car, the other into the computer and forget about it. So the device will recover from reboot, standby, hibernate without requiring any physical disconnect from either car or PC of the OBDPro, or having to fiddle with finding the correct USB port etc.
    Quote Originally Posted by michbound View Post
    Paul
  8. #38
    VENDOR - OBDPros
    Mar 2006
    As long as the OBDPro is powered up you will not loose connection through a reboot etc.
    There is however a case where you will have to reconnect, in case of the USB Scantool, if you power down the USB scantool by disconnecting from the DLC (but leave the PC hooked up) the next tine you power the OBDPro the software app running under windows will have to be restarted, this is due to the Virtual comm port software drivers on the PC. But again as long as you leave the OBDPro powered on you will not have an issue
  9. #39
    Oct 2006
    St. Louis, MO
    Signed up & Emailed.
  10. #40
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    is it compatible with all obd protocols? i'm a mechanic and we we our snap-on scanners at work everyday, but the downside to the snap on scanner is that we have to change "keys" for different protocols(vpw, iso, can, etc), but if it is compatible wit most obd protocols i woulld be interested, not to mention that i can test it on more than 10+ cars a day.
  1. BETA testers needed for StreetDeck Europe
    By god_of_cpu in forum StreetDeck
    Last Post: 05-27-2008, 03:02 PM
  2. New frontend needs beta testers
    By GoatMaster in forum Other Cool Front Ends
    Last Post: 03-10-2006, 05:39 PM
  3. Windows Mobile Smartphone Beta testers needed
    By zorro in forum PhoneControl
    Last Post: 02-23-2006, 08:57 AM
  4. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  5. X-MP3Pad is out! I need beta testers!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 07-15-2002, 03:33 PM
