Page 5 of 18 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 179
Thread: New OBDII scantool - Beta testers?
  1. #41
    Oct 2006
    signed up yesterday and emailed but no response yet
  2. #42
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by Injector View Post
    is it compatible with all obd protocols? i'm a mechanic and we we our snap-on scanners at work everyday, but the downside to the snap on scanner is that we have to change "keys" for different protocols(vpw, iso, can, etc), but if it is compatible wit most obd protocols i woulld be interested, not to mention that i can test it on more than 10+ cars a day.
    Yes it's compatible with all the OBD II protocols PWM, VPW, ISO-9141, KWP2000 and CAN 11 bit & 29bit (250 & 500 KBPS) . These are the protocols that all cars 1996 and newer must support.
    check out http://www.obdpros.com
  3. #43
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by fibregod View Post
    I have not caught up with all the emails from yesterday, I will get to yours as soon as I can. I am testing the units so that I can get them shipped out on Monday so I give me till tonight.
    Paul
  4. #44
    Oct 2006
    thanks for the quick response...I'l be waiting
  5. #45
    Variable Bitrate xs10x's Avatar
    Jul 2005
    Bronx, NY
    Signed up and emailed info to yaa, Waiting for link.
    `¨`¨`¨`¨` _____||¯.\__
    .:.:.:.:.:.:;!_(o)______(o)'i
    TruckputerX - Vortech SuperCharger Vid
    TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
  6. #46
    Sep 2006
    If you have room i have an 06 Titan. I would love to test it.
  7. #47
    Oct 2005
    Sounds good, still waiting for you email as well..no worries, I imagine you are busy.
    Okay, as to the power issue, one last question. Once you turn off the ignition, and shut down your computer - would the serial/USB scantool not loose power as well? Would this not then require you to disconnect once you started the computer up again? This is assuming that the OBDPro is not disconnected physically from the car or the PC.
    Really don't worry to much about it, I will order one when I get your email and test if out
    Quote Originally Posted by michbound View Post
    As long as the OBDPro is powered up you will not loose connection through a reboot etc.
  8. #48
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by canadiandream View Post
    No problem I don't mind the questions (I'll probably regret saying that). Actually there is always power to the DLC connector even when you turn the ignition off so if you leave the OBD connector plugged into your vehicles OBD port it will always be powered on even on ignition OFF. The OBDPro does consume a small amount of power but I leave mine plugged in in my vehicle and it has not drained my battery even after not having used the vehicle for 3 days. I have not measured the current draw but that's something I will do soon so people have an idea of how much power it consumes.
    Now if you yank off the DLC connector while your OBD Program such as scanmaster etc is running your scanmaster program will probably give you an error saying unable to connect but that is to be expected since you powered off the interface. In this case you will not have to disconnect the OBDPro just restart the OBD software on your PC
    Not sure if this helps?
    Paul
  9. #49
    VENDOR - OBDPros
    Mar 2006
    Just a quick update
    first thanks to everyone who agreed to test the interface, I have had an overwhelming response and am struggling to keep up with my email. I will be going through all the responses within the next hour, so everyone should have heard from be by tonight.
    At this point I would like to close down the beta signup. I would like to limit the list to about 10 folks so I can monitor the results carefully.
    (But I will accomodate every one who has responded to this thread prior to this message)
    There are a few folks who I have invoiced but have not responded, please check your Spam filters, maybe your ISP was too aggressive and canned my message. I will post a list of all the confirmed participants by tomorrow morning, that way if anyones not on there and should be can speak up. If anyone from the pending list cancels I will open the beta signup again.
    Everythings on track for shipping by Monday, but I might have to stagger shipments over two days so looks like most of the participants should have the interface in their end by late next week. Overseas folks might have to wait a bit longer.
    Lastly: I had one person mentione a broken link on the http://www.obdpros.con website. Thanks for the heads up; that is fixed. If anyone else notices anything wacky or messed up on the website please let me know also.
    Paul
  10. #50
    Oct 2005
    Sounds perfect man, can't wait to test it out. I will test the current draw on a few cars as well. You should be able to estimate total time till battery drain. Obviously an excellent feature in this case would be a battery monitor that would shut down the OBDPro completly before you drained your car battery for people like myself who plan to make it a permanent installation.
  1. BETA testers needed for StreetDeck Europe
    By god_of_cpu in forum StreetDeck
    Last Post: 05-27-2008, 02:02 PM
  2. New frontend needs beta testers
    By GoatMaster in forum Other Cool Front Ends
    Last Post: 03-10-2006, 04:39 PM
  3. Windows Mobile Smartphone Beta testers needed
    By zorro in forum PhoneControl
    Last Post: 02-23-2006, 07:57 AM
  4. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 02:22 PM
  5. X-MP3Pad is out! I need beta testers!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 07-15-2002, 02:33 PM
