Page 9 of 18 FirstFirst 123456789101112131415161718 LastLast
Results 81 to 90 of 178
Thread: New OBDII scantool - Beta testers?
  1. #81
    Jul 2005
    Rosemount, MN
    Paul,
    I am interested in knowing more and I thought you could use a bump here on the hardware ~ from what I gather you do not use the actual ELM327 chip, you have just copied it's communication to mimic the ELM327 correct? You stated in your last post: "There are a couple of things that I am changing such as the version string so you do not have to go to any extra steps to make it compatible with the vast majority of software out there." Are you actually making your hardware reply telling people it is in fact an ELM chip? Just curious how detailed you are designing your hardware to mimic the ELM communication. Also, I have noticed the ELM chip (even the latest ELM327 chip, especially on CAN) communicates at an extremely slow rate, most likely caused because of that translation the hardware is attempting to do. Have you run any speed tests between your hardware and theirs? I would be interested to know if your hardware runs faster then the actual ELM based hardware.
  2. #82
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by digimotojoel View Post
    Paul,
    Hi Joel,
    Thanks for the bump.
    1. Yes, Its not an ELM327 chip but implements the ELM327 commands so that the interface will work with the huge number of ELM327 compatible software. On an ATI command, the interface says "ELM327 v1.0a compatible - OBDPro v1.0", most software packages are able to deal with this since they do a substring search for the text ELM327. I had to mimic the ELM command set to maintain compatibility with all the software, though nowadays I hope someone will be willing to do a client implementation that would accept binary commands as it would also help reduce the amount of data being sent over the serial port. I am developing a version with a binary command set, but then looks like I might have to implement the front end also.
    2. The OBDPro does allow setting the communications speed all the way upto 128KBPS so at the higher speeds it will be faster than the ELM, I have done benchmarking against the ELM and will publish the numbers that I have soon, unfortunately I do not have the latest ELM chip so I am using version 1.0a, obviously the limiting factor is the speed at which you can send data out the narrow serial pipe.
    Paul
    www.obdpros.com
  3. #83
    Jul 2005
    Rosemount, MN
    Paul,
    If you build a tool that strips the communication down to a binary level we will support it. I understand your concern and seeing that the ELM already has a popular base for software I understand your reasoning behind implementing a similar method of communication, however these methods of communicating will become much more apparent in the near future when people start working on CAN compatible vehicles. If you have the ability to build a smarter/faster interface, do it.
  4. #84
    Jul 2006
    Just for the record:
    I received my OBDPro (USB) yesterday, connected it to my 2005 Acrua TL and my CarPC. I then installed the USB-Serial drivers that came on a CD with the ODBPro. Next I configured Streetdeck to connect to my ELM323 device on COM5 and everything works. Easy breezy!
    I am very happy!
    Steve
  5. #85
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by TheBiz View Post
    I am very happy!
    Steve
    Hi Steve,
    I am glad to hear that the interface is working well in your vehicle. We love to hear from our customers (especially when it's good feedback).
    Thanks for posting your experiences. (The check is in the mail ).
    Paul
    www.obdpros.com
  6. #86
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Dam, I miss the boat on beta. Otherwise, I would test on my 04 Matrix (aka Corolla) and 2K Accord.
    Too busy with RoadRunner stuff.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  7. #87
    Nov 2006
    Hernando, MS
    I am seriously considering going with this hardware. I am new to this, but have been needing something like this for a long time.
    Any other comments or recommendations anybody?
  8. #88
    May 2006
    Seattleish, WA
    Quote Originally Posted by powerlover View Post
    It's an excellent price on what appears to be an excellent design from a newcomer in the genre.
    I have three OBD II interfaces, an $80 box, a $125 box and a $350 box, I use each of them for different reasons. If this interface had been out when I bought my middle-priced box, I would have bought this one instead.
    I love the fact that this interface allows for a faster data rate, and for the geek, removes the "AT" interface layer thus allowing for tighter integration with the OBD II data.
    :: Mark
  9. #89
    Nov 2006
    Hernando, MS
    michbound, If I were to place an order, when should I expect delivery?
  10. #90
    Oct 2004
    right here
    i would love to try it on my 2006 honda ridgeline.
  1. BETA testers needed for StreetDeck Europe
    By god_of_cpu in forum StreetDeck
    Last Post: 05-27-2008, 03:02 PM
  2. New frontend needs beta testers
    By GoatMaster in forum Other Cool Front Ends
    Last Post: 03-10-2006, 05:39 PM
  3. Windows Mobile Smartphone Beta testers needed
    By zorro in forum PhoneControl
    Last Post: 02-23-2006, 08:57 AM
  4. Looking for beta testers for new DC-DC PSU
    By MikeH in forum Power Supplies
    Last Post: 05-18-2004, 03:22 PM
  5. X-MP3Pad is out! I need beta testers!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 07-15-2002, 03:33 PM
