Results 1 to 3 of 3
Thread: CAN OBDII - Can someone help me?
    Oct 2006
    I am trying to develop a scan tool for my Brazilian Ford Fiesta that uses the CAN bus for diagnostics. I am using a PIC 18F4680 for that and I have been able to enter the bus and monitor its messages. However, when I try to send an OBD request to the car, say:
    ID: 0x7E0 (ECU #1)
    02 (ISO 15765 no. of data bytes)
    01 (mode 1)
    01 (PID 1)
    00 00 00 00 00 (Padded with zeros)
    I get the following error message:
    7F (General response(error).... I should have received something like 41, right?)
    00 00 00 00
    Can someone shed some light on this? I have tried many different messages and I always get that disturbing 0x7F error code. Also, if I try ID 0x7DF I dont receive anything no matter what message I send. How can I make this work? Thank you.
    Jul 2005
    $7F is indeed a negative response. A negative response frame is formated as such:
    ARB ID: $XXX, B1: $0X, B2: $7F, B3: $SS, B4: $NN, B5: $XX, B6: $XX, B7: $00, B8: $00
    Where $SS = Service Requested (in your case Mode $01) and
    Where $NN = Return Code.
    Here is a list of some return codes:
    $11 Service Not Supported
    $12 Sub Function Not Supported - Invalid Format
    $22 Conditions Not Correct Or Request Sequence Error
    $31 Request Out Of Range
    $35 Invalid Key
    $36 Exceed Number Of Attempts
    $37 Required Time Delay Not Expired
    It seems to me that your ECU does not support Mode $01. There is little you can do about this. You can try another ECU try $7E1-$7E7. Maybe one of them will work for you.
    Good luck.
    Oct 2006
    Thank you for your answer. It does turn out to be that my car is not OBD II compatible via the CAN bus, however, I can use the ISO 9141-2 interface it implements. Thank you once again.
  1. Able to get voltage from OBDII?
    By aoLhaTer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-18-2007, 09:26 PM
  2. OBDII Signal Splitter (for Infiniti G35)
    By Caelric in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-14-2007, 08:32 PM
  3. OBDii on non-US cars
    By ramy_zohair in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2005, 01:30 AM
  4. FS: OBDII diagnostic interface
    By deskcom in forum Classified Archive
    Last Post: 12-09-2004, 11:24 PM
  5. @ Leddy OBDII
    By gyro in forum NeoCar Media Center
    Last Post: 12-08-2004, 06:43 PM
