Small Update.
planning on making an installer for the less java friendly people.
-added code for Linux
-settings now saved in a file called settings.txt
That is nothing like the 8192 baud ALDL protocol that I am working with. I have all the specs, commands, etc, just need advice on how to handle constantly streaming serial data with VB.NET.
Thanks for trying tho!
Jarrod - Holden VX S!
Small Update.
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
i know not too many ppl care. But since someone killed my car, my project is on hold till i get another.
but if for someone reason u need something about it, just give me a pm.
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
I would like to add the ALDL to my hand held OBDII device, www.sterntech.com, can you send me the information for the ALDL protocol?
Trampas
tstern AT sterntech.com
just a different gauge style
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
all black
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
Sorry for replying on this old thread. I am in the process of making an interface for my 1990 chevy van to show this data. I was wondering if you made more patches of your gauges software. A nice addition would be calculating the gas mileage, but there are a few variables you will need to have extra such as airflow.
If you have newer versions made, could you post it here?
My chevy is at the garage for repairs, and I will need to buy an aldl cable.
I have downloaded your source files.
If you think it is OK to use your sources. I am going to have a go at parsing the ds files posted here, it would be really useful so your solution isn't only for the regal you owned. There is a big change some of he fellow vanners here in the Netherlands will be interested too.
Probably most code will be refactored. Adding the options to view the meters you want etc. Is there anyone interested in new versions of this software on mp3car? (if I can get it to work off course)
http://www.mp3car.com/vbulletin/engi...ml#post1080254
I am going to add a parser to understand multiple datastreams based on the following ds files:
would there be more people on mp3car interested? If I get it working I will post it here, if I gt it working and someone will is interested. Some Dutch vanners are already showing some interest for this software.
Andre
Sign me up. I own a 1993 Chevy G20 and plan on doing something similar. However, I'm not sure if I will use the ALDL port or if I'll just custom wire all the gauge sending units to a Fusion Brain.
The turn signals will require a Fusion Brain anyway.
Check out my GMC Savana worklog.
Remaining tasks to facilitate vanputer installation codename "Enterprise":
- Edit skin to liking.
- Get compatible phone for mobilephone.net.
- Facilitate HVAC control.
