Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 73
Thread: OBD GM ALDL software
  1. #21
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    edmond, oklahoma
    i am in the proccess of trying to get data from my ecm. it is a 1227730, and that runs at 8192 baud. so far it seems the only thing that is going to work for logging with this ecm is the APU1 from moates with either Tunerpro RT or i believe tunercat. but i am also trying to tune it to get the new engine/ecm combo to work together. its the 3500 from an 06 malibu with a obd1 ecm.
    ok, i think im done bragging. but i am definantly going to keep up with this.
    Gathering parts----99% (I'll always want something else, its never 100%)
    Learning Centrafuse
    First Actual 98 Blazer LT Install
    First 08 Aveo5 SV Install
    87 Fiero GT waiting
  2. #22
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I have an 87 camaro with a '165 ECU, and wrote my own interface. If anyone is interested in some of my c++ code, I wrote it using a cross-platform library called Qt, so you wouldn't be able to compile it without that, but the concepts in it are useful for the communication. protocol.
    I warn you, the UI is ugly and the code is very dirty as it is still in development, but maybe it would be of some use to someone. Once I get my carputer into the camaro I'm going to be running this software full time.
    the MPG display doesn't work right, I'm still working on the function to calculate it, so don't get your hopes up on that one :P
  3. #23
    Apr 2007
    edmond, oklahoma
    is that ecm 160 baud or 8192? im guessing 8192 unless a conversion of some sort was done. i am waiting for my max232 chip to come in from mouser to finish up my 8192 baud aldl cable.
    Learning Centrafuse
    87 Fiero GT waiting
  4. #24
    Jun 2004
    Westminster, MD
    Quote Originally Posted by americasfuture2 View Post
    Mine is one of the "hybrid" ecu's. It does both, but I run it at 8192. usually. The 160 baud shows less than half the information that the 8192 does on mine.
  5. #25
    Apr 2007
    edmond, oklahoma
    im still learning about all these late 80s gm ecm's, never knew there was a hybrid. but from what i have been told, 8192 baud ecm is much better because it samples data and outputs it quicker than the 160 baud ecm. i dont remember how many times a second each samples. i just know from experience and what people have said after the conversion done on their fiero that it idles better, runs better, transfers power better, has better throttle response, and no rev at startup. along with other things that arent coming to me at the moment.
    Learning Centrafuse
    87 Fiero GT waiting
  6. #26
    Jun 2004
    Westminster, MD
    The hybrid thing I think was purely the '165 ecm. I get around 10hz sampling from mine in 8192 baud mode. I actually just upgraded the code in my chip to the 88' code, THAT runs much better than the '87 code, and the ALDL doesn't stop responding like my 87 code used to.
    The APU1 is pretty good from what I hear. I have the Ostrich 2.0 + ALDL cable combonation, but the APU1 allows you to read your stock chip, and burn new chips too (which is awesome) I should've gotten that
    Interfacing with the APU1 via ALDL should not be difficult at all, but TunerProRT is a good program to use, it's what I use to compare against my program and make sure I'm doing things right
    I'd like to finish my touchscreen compatible data logger, Tuner-Pro is very untouchscreen friendly.
  7. #27
    Apr 2007
    edmond, oklahoma
    next fri when uncle sam pays me im going ot order the apu1. thats also the day it comes back into stock. cant wait! but for now i am making the 8192 aldl cable with the max232 chip. we will see how that goes.
    Learning Centrafuse
    87 Fiero GT waiting
  8. #28
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    hey sorry for the late post. didnt see it and only found it now.
    haha
    if you are still interested and need some help im here now.
    car is gone though, woke up to a call from the cops and headed outside to see the car crushed from the back and pushed into the car in front of me.
    now got a 91 lincoln so thats why i dropped this...
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    bu-353
    still installing...
  9. #29
    Apr 2007
    edmond, oklahoma
    wow, my post was some time ago. that home made aldl cable, i never did try it. i did get the apu1 in. and it works great. i just need to learn to tune now.
    Learning Centrafuse
    87 Fiero GT waiting
  10. #30
    Jun 2004
    Westminster, MD
    I just got my new engine back from the machine shop, I'm hoping to have it in by the end of Jan. so I can start working on ALDL stuff again. Been working on OBD2 stuff in the meantime
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. delorme software replacement?
    By fortressgame in forum GPS
    Last Post: 11-10-2005, 08:48 AM
  3. WTB - Iguidance or OBD software
    By gdawg in forum Classified Archive
    Last Post: 09-20-2005, 08:43 PM
  4. Software solution for gLCD-based car-mp3
    By Novgorod in forum Software & Software Development
    Last Post: 07-01-2004, 08:59 PM
  5. myHTPC Software
    By the_new_guy in forum Software & Software Development
    Last Post: 06-05-2004, 04:51 PM
