very cool my van is a really expensive paper weight ATM so if i get a chance i will test it out
what ecus does it work with also are you familiar with winaldl i have the source code for it its written in c
thanks look awesome
After about 3 months away i decided to start developing it again.
So as it is right now... works for 83-87 gm aldl (might work for others but have only tested on my car) and my carputer is dead so i havent retested it for about a month (if you got mobo to donate that would be great).
not working for linux but soon will be.
you need to follow the readme in the comm folder to install a package in java.
then just double click on the jar file.
i will be working on it so ill update when i think i have done a good amount.
if you find it works for your car, please tell me so i can add it the list.
the same goes for errors and suggestions.
I know this is for a very limited amount of people (guessing like 3-10).
so i hope those of you who can use it enjoy it.
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
thanks look awesome
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
yea i know winaldl great program.
if you could send me the source that would be great i would like to take a look.
not sure the exact ecu number but it will be for 3.8 CLCC ecus. So if you have anything in that format it will work. If you dont it wont, though i could add it and probably will.
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
I like the look of the gauges, once you get it complete it might not be that big of an effort to make it work with the other scantools.
Looking forward to seeing the finished product.
Paul
Thanks.
by "other scantools" im guessing you mean like other software or obd2??
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
Hi 84RegalRider,
Yeah I was thinking that your gauges would complement some of the other software available on the market for OBD2 interfaces quite well.
There are some nice packages available for OBD2 but something Java based would afford the portability to allow use on any platform, I noticed you mentioned that your software does not run on linux yet but that you are working on it. I am guessing it's just a matter of getting the serial routines working properly?
Paul
I also began coding software for Holden (GM) ALDL 8192 Baud interface (http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm), but could never get the software to sync with the incoming serial data. Any pointers on using Serial ports in VB.NET would be appreciated...as well as any source code I could get my hands on.
Thanks,
Jarrod - Holden VX S!
http://www.geocities.com/MotorCity/Shop/9938/
looks like u got to send a request for data
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
