OBDII doesn't reset airbag lights by design. There are some tools out there that do it and use the same port, but they are not OBDII tools and are usually only available to dealers or mechanics at very high cost.
Most cars, particularly older ones, have a diagnostic mode override that will reset your warning lights that you can activate through some special trick like turning the ignition on and off while opening and closing the door. The trick is different for each car, but was how I reset my airbag light.
LinkBack URL
About LinkBacks
