Results 1 to 6 of 6
Thread: Another noob with another noob question :)
    Oct 2006
    Maryland, US
    Hey folks, nice board you got here!
    My goal is to have a unit in my car that would allow to display different combination of gauges and log data from them when neccesary. Plus it would be nice to have a GPS capability. If this unit ends up replacing the stock 6 disk changer then a CD/MP3 player needs to come along too. This will go in an 04 Subaru Forester.
    I am currently searching this board on keywords such us 'gauges', 'OBDII' and 'GPS' but would like to ask you guys to suggest a few more to narrow my search down.
    Low Bitrate PSYKO_Inc's Avatar
    Oct 2006
    Fairfield, CA
    There's a whole subforum related to OBDII, have a look in there for your gauges/OBDII info. GPS and CD/MP3 are both really simple to set up. For CD playback all you need is a CD-ROM drive mounted somewhere in the car. Alot of people use a slim external "laptop" style drive connected by USB. GPS is also easy. You will need a USB GPS receiver (about $50-$100 usually) and it will need a view of the sky to work properly. Most folks mount theirs on the dash or rear package shelf right by the glass. You'll also need navigation software. Most people on here use iGuidance. Have a look in our FAQ Emporium, you'll learn alot by reading thru there and generally lurking on the board soaking up info. Enjoy!
    1997 Chevy S-10, ext. cab
    CarPC Progress: 75% - Functional, but not quite finished.
    Check out my progress.
    FLAC W3bMa5t3r's Avatar
    Apr 2006
    Washington, DC
    Check out the OBDII Forum and look for "DigiMoto" I have their scan tool package and it works great.
    The W3bMa5t3r...
    Oct 2006
    Maryland, US
    Awesome! Thanks guys!
    Mar 2004
    Little Elm, Texas
    moved to the appropriate forum!
    welcome, good luck with your search.
    Jan Bennett
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    300 bucks and ill make mine for OBD2
    hope you find something you like.
    and welcome.
    Core duo
    1tb harddrive
    256 ddr
    8 lilliput
    still installing...
  1. Real Noob harddrive question
    By matabra in forum Newbie
    Last Post: 07-27-2006, 06:08 PM
  2. noob question about wiring
    By VW_Carputer in forum Newbie
    Last Post: 05-24-2006, 08:33 PM
  3. Dumb noob question
    By TaZMaNiaK in forum FrodoPlayer
    Last Post: 04-02-2005, 12:52 AM
  4. A nOOB question about monitors.
    By GATrooper in forum LCD/Display
    Last Post: 10-12-2003, 02:21 AM
