Alright well no one straight up seems to know or is willing to share anything about aftermarket ECU's so i have been doing an inordinate ammount of searching reading and more....and well this is what i came up with:
I have found 4 companies that make good aftermarket ECU's
3 of which are manufactured for you:
Haltech - http://www.haltech.com
Motec - http://www.motec.com
Autronic - http://www.autronic.com
1 of which is "open source"
MegaSquirt - http://www.bgsoflex.com/megasquirt.html
I was attacted to the MegaSquirt because of the DIY nature of it but it is very limited it seems and gives you hardly any help in programming.
I leaning toward an Autronic System because of its AutoTune feature. Although I want to have full control over tuning and will have therefore to learn a great deal about ignition and injection timing etc. This will give me a good basis to begin off of.
I also like the Motec systems because they have VERY detailed instructions.
Haltech has very advanced systems but seems to be very - get someone to do it for you. and thats a turn off for me.
This maybe the single most expenisve part in my whole set up so i want to pick it right.
Note that all have a computer interface and provide software (either through serial (RS232), Parallel (aka CAN) and USB (usually converted from one of the first two)
I have found that trying to install an OBD-II system and then get a converter for the computer would be kind of pointless and MUCH more expensive. I have also found that getting your hands on an unprogrammed OBD-II system is virtually impossible.
So thats what i know so far. Ill up date everyone as i learn more.
LinkBack URL
About LinkBacks
