Results 1 to 10 of 10
Thread: OBD II and Citroen Xsara
    Nov 2006
    Hi,
    Recently I bought citroen xsara 2.0 HDI and now I’m trying to make dumb OBD II cable. I found a few projects on internet on that topic so my question is: What is the best OBD software for Citroen (PSA) and dumb cables? What is the most used (or tested) OBD II interface circuit?
    (I will try to use this : http://hem.passagen.se/tomasf/obd2/ ) will this do?
    Best from Slovenia,
    Pohorc
    Nov 2006
    I have the same question.
    Maybe here is some cables?
    http://www.scantool.net/products/index.php?cPath=5
    Thanx in advance!
    Oct 2005
    UK
    Hi,
    When you say you are trying to make a dumb cable, what do you actually mean by this?
    You need to check the protocol, the car is likely to be using ISO, although this will depend on the age.
    The most well known and testing circuits are probably those based on the ELM Electronics chips.
    Hope this helps,
    Gareth
    Nov 2006
    UKOBD,
    With "dumb" cable I mean cable without ELM chip in the middle. Please check my link in first post.
    Mvts I’m waiting for the connector. Hope I will get it soon. I will “share with you” if my “little project” was a success.
    Pohorc
    Newbie folker's Avatar
    Nov 2006
    Berlin Germany
    www.obd-diag.com
    OBD-DIAG4000 (ISO,KWP,PWM,VPW.CAN,LAWICEL,VAG-Mode = KKL)
    .... a German project.
    Oct 2005
    UK
    Hi,
    There are plenty of straight cables available, however I'm not quite sure what you are looking to achieve with one?
    Gareth
    Nov 2006
    Hi!
    Ok. I´am very interested.
    Thanx in advance for all info!
    Oct 2003
    Copenhagen, Denmark
    If your Xsara is from 2000 or before there is a good chance it is not OBD compatible at all.
    Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    ok nice to see other xsaras owners around!!! i have a xsara 1400 vtr (ok not a VTS) but it is a year 2002.. so I am sure it is OBD compatible.. i am sure ThePohorc's HDI is a year +2001. I do have the same question however..
    ther is a good site for xsaras maybe if I have time I will search there myself
    http://www.xsarasportsclub.com/
    Mar 2008
    Thirsk North Yorkshire
    so far as I know www.xsarasportsclub.com closed a while ago, join http://www.cxoc.net/ it's a really good forum for xsara questions.. and the members are really friendly
    oh.. hello mp3car.. nice to meet you all
