Results 1 to 4 of 4
Thread: Is there OBD Connector in my Car?
    Nov 2006
    My car is Hyundai Elantra with a-CVVT engin,Made in 2006.Is there OBD connector in it?and How can I know where it is?
    Could somebody take some photos?
    Oct 2005
    UK
    Hi,
    You will have an OBD2 connector, it has to be within 2 foot of the steering wheel, and easily accessible. They are often covered with a clip off cover, or could be under the dashboard - have a nose about. You are looking for a rectangular plug that looks like this.
    Being 2006 you need to also bear in mind that your car is also probably using the CAN protocol.
    Good Luck!
    Gareth
    Mar 2006
    Colorado, but Canadian!
    Yup, you have one. All above '96 (I think) have it. Must be within a meter of the steering column like UKOBD said. Sometimes you must remove a few panels to get there, but it should be "easily accessable" as per the standard.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2007
    How to analyze OBD msg ?
    Hi,
    Can someone tell me how do i analyze the OBD information recieved from ECU?
    I am using CAN interface and i need to analyse the different data (DTC, Freeze frame ..) and display the recieved information using display interface.
    So how do i analyse different types of data recieved from ECU ?
  1. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  2. Hardwired OBD scanner and motor vehicle inspections
    By 01black_ac in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-30-2006, 12:40 AM
  3. OBD 1 Diagnostics software?
    By MaleBuffy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-13-2005, 08:05 PM
  4. OBD Diagnostics connected all the time?
    By Zoltan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-23-2004, 03:47 PM
  5. OBD USB or LPT1 Connectors?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 09-19-2003, 11:01 PM
