What does the refresh rate from a typical
obd-ii reader depend upon ? Is the protocol ? Or the interface ? the
software ? the ecu/pcm ? or what ?
I read somewhere that OBD-II mandates a minimum bus idle of 300ms - that's a refresh rate of about 3.3 Hz. If that’s true then its really not possible to make a scanner read faster than that.
But I have also heard claims to the effect of 35Hz! Are these proprietary interfaces that implement it completely differently ?
What are some of the "faster" types available currently ?
