Results 1 to 10 of 11
Thread: ELM327 -> '06 civic Si ??yes...no?
    Variable Bitrate portabuddy's Avatar
    Feb 2006
    mississauga, On.
    befor getting a OBDII i decided to do a bit of reading then i found out that the 327 that is faster and has a better capacity might just work with my new car. i asked the seller on ebay if they had experiance with them and he said that one of the cars tested was the 06 civic.
    now i'm usinf digimoto with the bit rate set and the port selected and all the info i get is the vin and thats it, my carputer isnt quite done but after i installed my exhaust im getting tired of the eng. light staying on and wanted to test the guages and other toys as well as clear the codes(o2 sensor error??i think )
    my question is what do i have to do to get it to work, is there a specal way to do things like turn the key on then off the start the car connect pump the gass and spin around three times? or what? can some one please help...
    ps im not normaly so dumb sounding. thanks.
    Life Dosn't come with a reset button, if it did you might as well turn the game off.
    Feb 2006
    mississauga, On.
    oh and i forgot to mention that the device works well my buddy used it to diaglose his car but that was a vw, and mine is a honda and i think that there has to be some kind of procedure to get it going.
    Jul 2005
    Rosemount, MN
    It sounds like you are using the Digimoto 5.0 beta from what you described. Does your 06 have multiple ECUs? You should know that we just released an update to our beta yesterday (rev 14) which has multiple ECU support for the ELM interface, you should download this latest update and give it a try.
    http://forums.digimoto.com/shwmessag...MessageID=3045
    Feb 2006
    mississauga, On.
    eaven though i didnt have much sucess with your program working for me i like the useabilty of it and i would like to stay with it(since i already bought it ) and this the multiple ecm's thing dose make sense i will try the update a bit later, do you yourself or anyone else have any exp. with the 06 civics? and how to read the info???, just because i have used some freewhare that didnt work either.
    Jul 2005
    Rosemount, MN
    I am fairly confident the vehicle contains multiple ECUs (someone on the board can correct me if I am wrong). The data coming back also suggests that the software was only communicating with one ECU (partial data). I would be surprised if this update did not provide full access to your vehicles information.
    Feb 2006
    mississauga, On.
    Great now im going to go home at 12:00am download it and get ti installed on my laptop and play with my car untill 4:00am, you see what you did...just kidding thanks alot, and you are right threre are three that i know uf, the VECU(inside on the passenger side) LECM(in the dash) and the ECM(under the hood) and i think that it was communicating with the VECU(vehical-electronic.c.u.) insted of the ECU(engine controle unit). but now that the problem is solved thats good. also is there a way i can make a new guage skin? i want them to look like the ones in my car. if its not done jet can you please make the guage a seperate file that i can manipulate myself in the next beta version.
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Hi.
    I tried installing the above mentioned trial software but I keep gettting errors when I try to register it as a trial version. It says that the serial number is incorrect. Any help would be deeply appreciated
    The road is long but we are getting there.
    Jul 2005
    Rosemount, MN
    We are currently running as a closed beta, which means existing customers are being given license keys to test with. We will move into an open beta shortly with the application at which time everyone will be able to use it (in trial or licensed mode).
    Dec 2003
    Greece
    oh. Ok. thanks for the reply
    Low Bitrate erie's Avatar
    May 2006
    USA
    portabuddy,
    Did you ever get access to all the systems in your Si?
    06 Galaxy Gray Si #0308
    CarPc Progress -
    10%---------50%---------100%
    -[XXXXXXXXXXXXXXXXXXXXXX]-
  1. 06 Honda Civic EX Firewall breakthrough
    By nevid77 in forum Car Audio
    Last Post: 02-24-2007, 10:55 AM
  2. carputer on civic 06
    By HeLLz aNgeL in forum General MP3Car Discussion
    Last Post: 02-12-2007, 11:18 AM
  3. Custom Dash with 700TSV for 02+ Honda Civic Si
    By xmadcowx in forum Classified Archive
    Last Post: 09-06-2005, 11:12 PM
  4. 1999 Honda Civic SI HondaPuter
    By Chris732 in forum Show off your project
    Last Post: 08-11-2005, 11:37 PM
  5. anyone tried an install on a 03 Civic Si?
    By Cheech in forum Newbie
    Last Post: 03-19-2005, 08:19 PM
