Results 1 to 7 of 7
Thread: Need help to figure out OBD ii connections
    Newbie virengoyal's Avatar
    Nov 2006
    Bangalore, India
    Hi Folks,
    Im new at this carputer concepts, but decided to try my hand at it. I have some questions regarding the OBD ii conections.
    Here is an idea of my setup.
    1. ITX mobo.
    2. Centrafuse 4.1
    3. Touch screen.
    4. Drive a suzuki swift
    Now i want to get the OBD readings from my car.
    1. what hardware do i need to connect the onboard computer to my car pc?
    2. Will centrafuse support the OBD ii reading or do i need to have another software running?
    Please give me your valuable comments on this.
    Thanks a ton and appreciate your help.
    Regards
    Viren
    VENDOR - OBDPros
    Mar 2006
    What year is your swift and was it made for the US market?
    Centrafuse will support all ELM327 compatible interfaces so it will be able to get the OBD readings provided you get a compatible interface, but the interfaces require an OBD II compatible vehicle (all 1996 and newer vehicles in the US will support OBD II)
    I make an interface that works with centrafuse. Check out www.obdpros.com
    Paul
    www.obdpros.com
    Nov 2006
    Bangalore, India
    Hi Mich,
    Thanks for your reply, My car is a 2005 model swift. Do japenese cars follow the ELM327 standars?
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    Well, I have a Mazda6 JDM specs (CAN bus protocol) and the ELM327 works perfectly. Now if I could only find some open source VB OBDII software it would be great.
    The road is long but we are getting there.
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by virengoyal View Post
    Hi Mich,
    Typically Japanese cars sold in the US before 2006 generally use the ISO9141 protocol, this is supported by the OBDPros interface.
    Paul
    www.obdpros.com
    Nov 2006
    Bangalore, India
    thanks once i figure out what connection and protocols my car runs on...ill will try and figure out my next step. Just recieved delivery of the MOBO...back to the test bench to get things running...Wish me luck
    Nov 2007
    hi there.. did you get you OBD working on your swift?
  1. Calculate HP base on OBD II data?
    By god_of_cpu in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-20-2011, 02:08 PM
  2. OBD II and Citroen Xsara
    By ThePohorc in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-02-2008, 09:41 AM
  3. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  4. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  5. Where went the Guages in the OBD II plugin?
    By bns2000 in forum Centrafuse
    Last Post: 08-11-2006, 11:39 PM
