Results 1 to 2 of 2
Thread: All New PCMSCAN v2.0!
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Introducing the most powerful and advanced software available for your ELM interface! This new and improved version of PCMSCAN™ crushes the competition. PCMSCAN™ is an OBD-II diagnostic scantool that no vehicle owner should be without. In a class by itself, this state-of-the-art software comes fully loaded with new features. Here are just some of the things PCMSCAN™ can do for you:
    -Find out the cause of your check engine light, look up trouble codes, and even turn off that annoying light and save a trip to the dealer.
    -Test your car’s emissions readiness.
    -Monitor and log data for a variety of parameters. View it with maps, gauges, tables, and graphs! Pause, fast forward and rewind your log files.
    -Check out the new drag strip feature! The drag strip displays a countdown and timing light and measures your launch and reaction time. At the end of your run, you get a timeslip with the stats from the run.
    -If you use aftermarket performance parts, the new digital dyno feature will let you test horsepower and torque to measure their impact on your vehicle's performance-- just try out the dyno and see if those parts were worth the money!
    -Customize your own high-resolution dashboard with our new DashXL™ technology! If you own a CarPC, you’ll love the new DashXL™ system! This system features the most customizable dashboard editor on the market!
    -For the power users out there, PCMSCAN™ now has built-in Javascripting support to do custom calculations on OBD-II parameters and data.
    Stop by our website and download it today!
    Brian @ Palmer Performance Engineering, Inc.
    http://www.palmerperformance.com
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    Here are some screenshots of some of the new features of PCMSCAN:
  1. PCMSCAN integrated into RR
    By sandworm in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-21-2009, 09:54 PM
  2. ProScan v2.0 - Professional OBD-II Scan Tool + Dyno
    By ProScan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-08-2009, 01:55 PM
  3. PCMSCAN + Subaru, which adapter
    By benetton in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-28-2006, 02:32 AM
  4. PCMSCAN embedded?
    By bigjoe22 in forum RR Skins
    Last Post: 04-18-2006, 04:57 PM
  5. mazda 6 carputer v2.0
    By skeurton in forum Show off your project
    Last Post: 06-23-2004, 05:37 PM
