Typically the USB adaptors need a host USB on the other end, pocket pc's generally do not implement a host usb type port, and even if you buy a CF card that gives you host usb on the pocket pc end the custom drivers required by the adaptors means you will have very little chance of the USB versions working with the USB adaptors.
Best approach is to get a serial adaptor and find a pocket pc that has a serial port.
Another approach is to use a blue tooth dongle with the serial adaptor and just use bluetooth on your Pocket PC (Provided your pocket pc has bluetooth)
Paul
www.obdpros.com
LinkBack URL
About LinkBacks
