Results 1 to 6 of 6
Thread: Volvo compatible obd II reader?
    Jun 2003
    Hi,
    I have been trying to buy an obd II reader for my Volvo S60R -2004 but I have not yet gotten any answers from vendors stating that their interface works with my car.
    Does anybody know of an interface that works on my car?
    /L-O
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Quote Originally Posted by loscooby View Post
    Hi,
    /L-O
    Take a look at http://www.troublecodes.net/articles...xplained.shtml . That explains how to check the vehicle your self to see if it is OBD-II compliant.
    I installed my carpc into my pet Kangaroo, mate.
    VENDOR - OBDPros
    Mar 2006
    Hi,
    /L-O
    If it's an US based vehicle any of the standard OBD II interfaces would work. I imagine a 2004 volvo probably has CAN.
    The OBDPro should work on the Volvo. I have tested it on a Volvo S40 (2006)
    But again as long as it's a US based vehicle you should have no problems using any multiprotocol OBD II interface
    Paul
    www.obdpros.com
    Feb 2007
    Thumbs up
    Hi
    The best you can do is buy VADIS software and Hardware from:
    http://www.oficinapt.110mb.com/OBD2/index.html
    http://www.oficinapt.110mb.com/OBD2/VCT2000.jpg
    Then, you will have oficial software for full diagnostic,parts catalog and design and function.
    I both one from them, and work without any problem on my S80.
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    Although I agree in general, VADIS is obsolete and has been replaced by VIDA. Both the old and new systems are compatible with CarDAQ, but you could use the vct if you already have one or want to pay twice as much as necessary. The factory software is surely the right thing to use -- it's awesome.
    Constant Bitrate StaggRLee's Avatar
    Feb 2005
    Seattle, WA
    Hi,
    /L-O
    Any OBD reader that supports the ISO standard will work with the '04 S60R.
    I use Alex Peper's OBDII cable but a newer multi-protocol Elm (325?) is a better choice due to its open specification and broader support across 3rd-party applications.
    You will only be able to read std. OBD engine stuff though, you can't see things that only the CAN bus knows about like boost. Even if the adapter claims to support CAN. I know of no OBD/diagnostic S/W with the exception of VADIS/VIDA that can and for that you need the $2k VCT2000 pod.
    Recognize this interior?
  1. can some one recomend a OBD II reader
    By crash893 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-05-2011, 06:55 PM
  2. OBD II and Citroen Xsara
    By ThePohorc in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-02-2008, 09:41 AM
  3. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  4. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  5. Comments on BR3 OBD Reader
    By sontakke in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-13-2004, 08:57 AM
