Results 1 to 4 of 4
Thread: OBD not respond on VW GOLF4 1.6!
    Low Bitrate ilyassx's Avatar
    Oct 2005
    Belgium, Denmark
    Question OBD not respond on VW GOLF4 1.6!
    So, i've tried googling to resolve this problem but I didn't found any answer.
    Recently i've bought a VW Golf4 1.6 petrol engine 1999, when I connect the car via ELM327 based scanner I got the error message below, I tried many softwares but still the same problem.
    I tried the same ELM327 scanner on VW GOLF3&4 TDi and VW Touran and it work correctly
    Any suggestion about that guys.
    I own this scanner http://www.skpang.co.uk/catalog/prod...c540e78702b238
    Thanks.
    The old setup http://flickr.com/photos/ilyassx
    The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
    Jetway J7F2WE VIA C7 1.5 GHz
    512 DDRII 533
    3.5" SATA2 H.D.D 200GB
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    PROGRESS:[########-]90%
    Newbie TruCypriot's Avatar
    Feb 2006
    UK, East London
    not sure how u are connecting the scanner to your computer but i had a similar problem with mine too, i found that if you connect the scanner to a computer with a proper RS232 port it works like it should, when i first tired it i had one of those silly belkin boxes that converted from rs232 to usb.
    - Forget headunits, its all about CarPCs -
    Progress {|||||||||---}
    Helix 5ch Amp @1850w
    Helix 17cm Component speakers x 2
    Audiobahn 12" Sub @400w RMS
    boot mod
    PPE
    PPE is offline
    PPE's Avatar
    Mar 2006
    What software are you using in that screenshot? It looks like our PCMSCAN software. If so, contact me, I may be able to help you figure out why it is failing.
    Don't forget to check out our new PCMSCAN v2.0! It comes loaded with new features like a dyno, drag strip, DashXL™ system, Javascripting, and more! Also, don't forget to check out our dashboard design contest. You could win up to $200!
    Brian @ Palmer Performance Engineering, Inc.
    http://www.palmerperformance.com
    Oct 2005
    Belgium, Denmark
    Quote Originally Posted by TruCypriot View Post
    I use the RS232 ELM327 scanner version connected with proper RS232 no HUb no converter, and it works in the other cars exept that GOLF4 1.6 I tried it in 4 differents cars but all of them are diesel engine TDI, it is a difference between petrol and diesel protocol???
    Quote Originally Posted by PPE View Post
    I use the PCMSCAN 1.4.3 is the perfect software for me But i think the problem is not coming from the software, I tried other open source softwares like scantool.net... but still the same problem.
    Hope someone can help me to resolve this problem.
    Thanks,
    512 DDRII 533
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
