Results 1 to 6 of 6
Thread: Q about querying enhanced PIDs
    Jul 2006
    If I understand correctly, and correct me if i am wrong, it is 'technically' possible to query any pid including enhanced/mfg specific from obd2 using any obd2 interface (like the obdpro), except that you need to know what command to send and how to interpret the response, and that information is available only by paying a big royalty ($$) to the manufacturer. Is that all correct ?
    Isn't there a ruling/regulation (or was going to be) that mandates all manufacturers to release that information to public ? or am I mixing that up with something else ?
    Jul 2005
    Rosemount, MN
    Yes, I believe there is something in the works that will require manufacturers to release this information to the public. I can't think of it off the top of my head, but I was just talking with someone about it the other day.
    There is some information that is buried around the internet, but to complete full integration you would need a working relationship to retrieve this information.
    I believe there may need to be some hardware modifications to work with Chrysler enhanced functionality, but I have done little research in the area of Chrysler specifically.
    You can retrieve enhanced sensor readings if you know the codes.
    Jul 2006
    That's very encouraging news!
    I will try digging around the net and see if I find anything but right now all I am interested about is just few sensors for Honda/Acura -
    Oil Temp/Pressure
    ATF Temp/Pressure
    Knock Sensor
    If I can get something for these I'd be very happy!
    (p.s.: i just noticed you're in rosemount. i am not far from there)
    Jul 2005
    Rosemount, MN
    I've actually been paying attention to that "Minnesota members get together" thread going on in another forum on mp3car, I haven't made a post but I'd like to check it out some time. My office is located in downtown St. Paul, if you are ever up for it we should grab lunch sometime.
    Jul 2006
    thanks. I will watch that thread too.
    too bad I didn't know about yesterday's get together a little in advance. It was like virtually in my backyard!
    i will send you a pm..
    Jan 2007
    Hi there...
    I am interested in getting the readings you mentioned above from my car as well (Opel 2006).
    Any idea how I can issue the commands (is there something like a terminal? would the response echo on there?) and what the format of those commands would be like?
    Also if I have access to an Opel official diagnostic tool (Tech 2) is there any way I can retrieve those codes? (even if I have to connect its interface with my obd interface and read what its sending)
  1. Ford Enhanced PIDs
    By chewwtoy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-20-2015, 01:46 PM
  2. Internet enhanced GPS Sat Nav
    By SteveC in forum GPS
    Last Post: 11-16-2006, 03:49 PM
  3. Enhanced Parameters?
    By dabigguy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-28-2006, 05:52 PM
  4. Enhanced Graphics Feedback
    By veetid in forum Centrafuse
    Last Post: 07-25-2006, 10:17 AM
  5. Anti-glare and enhanced brightness on Xenarc
    By S4Per in forum LCD/Display
    Last Post: 04-06-2004, 03:35 PM
