Results 1 to 6 of 6
Thread: mitsubishi galant
    Dec 2006
    Smile mitsubishi galant
    hello,
    plz i have a mitsubishi galant 1998 it have MUT-II interface is it the same as obd-II or not ...so can i use a obd on my ride???
    VENDOR - OBDPros
    Mar 2006
    If you are based in the US the 98 Galant would be OBD II compliant so you can use an OBD II scantool.
    If it's non US based all bets are off.
    I Think the MUT-II is a mitsubishi approved scantool interface.
    Paul
    www.obdpros.com
    Dec 2006
    thanx for answer me ...
    its not US its for gulf specification ....almost japan standards....
    so u thing i must bring MUT-II not OBD-II
    VENDOR - OBDPros
    Mar 2006
    Quote Originally Posted by colombiano View Post
    Yeah I think it's safer to go with the MUT-II unless someone on this list can confirm that the gulf Mitsu has OBD II support
    Paul
    www.obdpros.com
    Aug 2005
    Orange County, NY
    You can use EvoScan. http://www.limitless.co.nz/EvoScan/
    Prior to 1996, Mitsu didn't use standard OBD, so you'd have to go through the MUT-II/I interface which this will. You do need a specific cable from Tactrix to interface with the car though. The nice thing is that this cable supports reflashing the car's ecu, however I don't know if they've gotten anywhere with the pre-2001MY Galants yet.
    Dec 2006
    hiz
    plz what is the free logging software i can use with openport 1.3
  1. 2005 Mitsubishi Evolution VIII
    By Evolution VIII in forum Show off your project
    Last Post: 09-22-2009, 01:33 PM
  2. 2002 Mitsubishi Galant
    By UM_Fan in forum Show off your project
    Last Post: 02-04-2009, 06:55 PM
  3. 2001 Mitsubishi Galant Install
    By goosey2099 in forum Show off your project
    Last Post: 05-28-2008, 11:28 AM
  4. 2004 Mitsubishi Galant Dash
    By EsKALad in forum Fabrication
    Last Post: 05-15-2006, 10:50 PM
  5. 2000 Mitsubishi Galant
    By djScript in forum Show off your project
    Last Post: 05-16-2005, 04:11 PM
