To be honest, I don't know what protocols are used on the AU. Only that the BA supports CAN and ISO.
Sorry I couldn't be of more help. But it might be worth your while poking around www.fordforums.com.au or www.fordmods.com.
Lukeyson
Have been searching forums for ways to make this unit work with my AU2 XR8 falcon
it has an OBD2 type connector - but I am unsure if it uses the std odb2 protocols
With an NGS star diagnostic unit - I can get all the pids and also retirieve real time information - but borrowing it from work is a nightmare
Does anyone know whether the elmscan5 will pull information all the information from the car.
I can connect to it - using pcmscan but onlly 8 of 98 pids are identified
If there is a config file to make this work - I am interested in knowing the details.
I am trying to diagnose a problem with the car - prior to doing an edit to the ECU
ANy information or help would be appreciated.
BTW - the scantool v1.13 software does not recognise connection with the ecu - PCMscan seems to give some information - still trying other softwares - but i have the feeling it could be an obd1 with a odb2 interface on the car???? - stumped
Will try the hyperterminal and see if I can get some detials re-connectivity of the elmscan device
What do others use to get the pids?
Thanks in advance
O
Lukeyson
