Results 1 to 7 of 7
Thread: OBD2 All In One
    Dec 2006
    Leamington, Ontario, Canada
    Question OBD2 All In One
    for christmas i got the OBD2 All In One, and with it i received this little red connector with 4 pins, no cable for it, what is this for, am i supposed to make my own cable, or what.
    Constant Bitrate legacy05gt's Avatar
    May 2005
    Georgia
    you should receive a the ODBII cable to go from your car to the scan tool device and a serial or usb cable to go from the device to your PC.
    if you got neither, you got pwn3d.
    Progress:99% not 100% because theres always something to do...
    Centrafuse on XP (lited)
    EN15000
    120GB 2.5" SATA HD
    1GB DDR2 Ram
    M2-ATX PS
    Slot-Load DVD
    BU-353 GPS w/Mappoint 2k6
    DWW-700M
    Jul 2005
    Rosemount, MN
    Sounds like you might be talking about something like this:
    http://www.obd2allinone.com/sc/detai...?item=obd2conn
    The OBD2 All In One interface requires an OBDII cable and a Serial cable. Perhaps you received this in the package and someone accidentally ordered you the extra red connector?
    http://www.obd2allinone.com/sc/details.asp?item=obd2ser
    If all you got was an interface and that red head, you will need to either make an OBDII cable or purchase one. You will also need a serial cable or a USB cable depending on what type of interface you purchased. Without seeing a picture of everything you got that is the best I can do.
    I noticed you put a 1988 Mercury Grand Marquis as your vehicle on the forums. That vehicle is not OBDII compliant. Not sure if you knew that or not, but an OBDII device will not function on that vehicle.
    Dec 2006
    Yea or get MoBilScan have a look at www.mobilscan.dk
    then you dont need the cable
    Newbie intravino's Avatar
    Feb 2007
    Connectors or cables
    Quote Originally Posted by mastercom2003 View Post
    For the lowest prices on obd2 connectors, checkout:
    Feb 2007
    Thumbs up
    Quote Originally Posted by intravino View Post
    http://www.carplugs.com/products.html
    Or, you can check with the new Portuguese homepage:
    http://www.oficinapt.110mb.com/OBD2/index.html
    Seems they have the lowest prices!
    Feb 2007
    Quote Originally Posted by FredOBD2 View Post
    10 Euro's for a female connector with 6 pins plus Shipping, Yeah that is Really Cheap, Maybe in Portugal or Brazil! But not Here.
    Maybe the other stuff in the catalog but Not the connectors.
  1. Technical data from obd2
    By Stephan in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-20-2011, 01:10 PM
  2. Help: OBD2 Extension Cable?
    By LarryMZ3 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-19-2008, 05:36 PM
  3. Future (way future) feature idea - OBD2 and VFD
    By Jahntassa in forum Centrafuse
    Last Post: 12-13-2006, 10:29 PM
  4. OBD2 protocols??
    By nvmotorz in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-10-2006, 07:54 AM
  5. obd2 interface
    By Rita in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-09-2005, 02:57 AM
