Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Audi A4 speed output signal!
  1. #11
    Aug 2006
    Seattle, WA
    try navplus.com its all about the audi nav units
  2. #12
    Jan 2007
    Glendale, WI
    Pre-CAN Bus Audi's and VW's use what's called the GALA wire for speed sensing on their nav units.
    Check out http://www.navplus.us
  3. #13
    Mar 2004
    There are a couple places you can get speed signals. Off the top of my head I think its the green and white wire but check your bentley before tapping. You can find it 2 places behind the dash. The first place is going to the back of the instrument cluster in your dash.... kind of a pain to get to.
    OR, the easier place: One cool VW/audi feature is the speed sensitive wipers. Behind your lower dash once you locate the wiper relay you will also find a VSS line going to it. You can tap that line for your navi unit.
  4. #14
    Maximum Bitrate david69leonard's Avatar
    Oct 2006
    Texas
    Dont most GPS units tell you your speed from the satelite? So why would you need to find the speed sensor wire for your vehicle?
  5. #15
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by david69leonard View Post
    Some use it as a double check. That is how the Prius can tell you how fast you are going even if you are drivng in a tunnel!
    Some also use it as a more secure way of knowing if the car is stopped or not to allow you to enter an address and stuff.
    1.9in x 2.9in -- 47mm x 73mm
  6. #16
    Oct 2006
    Texas
    Gotcha!!!
  1. Mid-console in Audi A4 -96
    By Nesvik in forum Fabrication
    Last Post: 10-05-2005, 04:59 PM
  2. My Audi A4 -97
    By Dj_Aleks in forum Show off your project
    Last Post: 08-02-2005, 06:59 AM
  3. Is all coax/optical spdif output created equal?
    By Choser in forum General Hardware Discussion
    Last Post: 12-19-2004, 03:48 PM
  4. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 09:30 AM
  5. TV signal + Fast Speed = Bad picture
    By ODYSSEY in forum General MP3Car Discussion
    Last Post: 11-28-2002, 10:39 PM
