Results 1 to 3 of 3
Thread: obd-II on a chrysler neon
    Jan 2007
    united kingdom
    hi all any one know if a chrysler neon year 2000 model in the uk is odbii complient or not iam not sure as all the websites with deatils on odbii only list the dodge neon models. thanks for your help
    _
    Mar 2004
    Little Elm, Texas
    if it's post 1996 it should be OBD-II complient...at least in the states that's the way it is.
    Can you see the port under the dash?
    It should be a two row port. A pic of it will help us determine.
    Jan Bennett
    VENDOR - OBDPros
    Mar 2006
    , also check this link
    http://www.auterraweb.com/obdiipinout.html
    That should tell you based on the pin's what protocol you might have, most likely if you have the connector then the neon should support ISO-9141.
    Paul
    www.obdpros.com
  1. Need help to figure out OBD ii connections
    By virengoyal in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-19-2009, 06:03 AM
  2. OBD II and Citroen Xsara
    By ThePohorc in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-02-2008, 09:41 AM
  3. Confused about OBD II
    By tom2112 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-19-2007, 02:06 AM
  4. does this connector means i have obd II ? (Buick 95')
    By tomer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-03-2007, 08:03 AM
  5. Where went the Guages in the OBD II plugin?
    By bns2000 in forum Centrafuse
    Last Post: 08-11-2006, 11:39 PM
