Results 1 to 8 of 8
Thread: Mazda PIDS
    Aug 2006
    Mazda PIDS
    Hey everyone, I was wondering if anyone had a list of the PCM Parameter Identification (PIDS) for the Mazda RX8. They define things such as RPM, Fuel Pressure, Air Temp, etc. I've seen a few posts mentioning them, but have not seen a list.
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    Mazda, of course, supports the same mode $01 generic OBD2 PIDs defined in SAE J1979 as all automakers. RPM $0C, Fuel Rail Pressure $0A, Intake Air Temperature $0F, etc.
    The mode $22 enhanced PIDs for mazda will depend on the make/model/year, but many of them seem to be the same as Ford. If you find a list of the Ford enhanced parameters, just try them out. You might have luck!
    Aug 2006
    Well, I have a 2005 Mazda RX8, 6-speed. I would like to see the enhanced PIDs....any idea where? I've looked and haven't found any...
    Jul 2005
    Michigan
    Enhanced Mode PIDs are generally not freely available. You have to pay for them. The cost is about 7,000 per year from Etools. It may not have all of the PIDs you require however. But it's a start.
    Jan 2007
    Aurora, TX
    Here's Mazda's Enhanced Sensor List. Not sure if it will be any help.
    Todd
    DFW Texas
    Jul 2005
    Rosemount, MN
    The parameter lists are really meaningless without the PIDs associated with the parameters. Without the identification codes you can not retrieve the sensor values.
    Mar 2007
    Rutherford, Australia
    I'm interested in any list of codes from Ford or Mazda to see if they map to my Ford PIDS.
    I have seen some codes from a 2000 Focus which might help.
    If someone has any access to Mazda or Ford custom PIDS I would gladly give a case of beer for a PM.....
    (BTW, a 'case of beer' is a standard Australian unit of measure provided to a 'mate' when assistance is provided when working on a car....I felt the need to explain that one in further detail.)
    Lukeyson
    Oct 2011
    pids
    there is one freeware program which supports some enhanced pids for mazda. it works with obd-2 ELM 327 compatible scanners
    http://m3scan.narod.ru
  1. Mazda 6 console skin
    By DiNASTY in forum RR Skins No Longer Supported
    Last Post: 04-16-2009, 06:06 AM
  2. Ford Enhanced PIDs
    By chewwtoy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-10-2007, 01:46 PM
  3. 1997 Mazda MX6
    By slipmatt in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-18-2006, 08:12 AM
  4. Brandon Mazda Meet: (March 19th 2005)
    By Cyber_Drone in forum MP3Car Gatherings
    Last Post: 03-19-2005, 09:52 AM
  5. Mazda and more car auto products
    By ToxicPoison in forum General MP3Car Discussion
    Last Post: 03-12-2001, 02:59 PM
