Centrafuse native OBD II dashboard will not work with autotap since autotap uses a proprietary format.
The OBDPro scantool works under centrafuse since it uses an ELM327 compatible command set. Other ELM327 based scantools will also work with centrafuse such as the OBD2allinone and the ELMScan.
So all you need is to order one of the above mentioned scantool since it comes with everything needed to work with centrafuse.
Paul
www.obdpros.com
LinkBack URL
About LinkBacks
