Is There someone that help me?
Luca
Hi,
I have Land Rover Discovery TD5 05/2002, the elm323 chip is correct for my car?
Thank you to all.
Luca
Luca
Check this link
http://www.auterraweb.com/obdiipinout.html
and identify if you have the OBD II connector and what pin's are populated or post a picture of the connector in your vehicle and then someone here can guide you...
Paul
www.obdpros.com
Hi,
No, the TD5 is not OBD2/EOBD compatible - you need a specialist tool for this particular vehicle.
Gareth
Does anybody know any technical details on the protocol that the Td5 / Bosch (?) system uses - I assume there is different hardware required for the interface than tat supported by the ELM systems.
Any info would be appreciated as I think it would be great to try and get something working that was cheaper than the rovacom systems
The whole system is very different. We made the decision to supply Rovacom having tested in extensively - it is the best tool for the job, and compared with the other tools for this range very good value.
Remember that you do only have to buy the software modules you need, and can add to them over time if required.
Gareth
