Results 1 to 10 of 14
Thread: bmw e46 owners obd2
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Question bmw e46 owners obd2
    Hi,
    Have done a bit of research on obd2,on a bmw 3 series e46 (i have 320 diesel)
    seems to be a mixed view on the 16/20 pin connection, and whether the interiour connector is actually live. Has anyone had any success using the obd2 on the inside of the car?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    Oct 2005
    UK
    It will depend very largely on the age of your BMW - what age is it?
    Nov 2006
    Wales, UK
    Quote Originally Posted by UKOBD View Post
    august 2002
    CarPuter Progress:
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by shoulders View Post
    since 1996 cars in america have to have the OBDII socket in the cabin and from 2002 in europe.
    Some BMWs in europe before 2002 were obdii compliant but did not have the OBDII socket, in these cases BMW will tell you they are not compliant. Checking of pin 2 (sometimes labelled OBDII) or pin 17 (TXII or second K line) of the 20 pin DLC under the hood, they are only present if OBDII is supported.
    From another thread.
    Nov 2006
    Wales, UK
    Quote Originally Posted by Enforcer View Post
    thanks dude,am assuming i have since the car is august 02...
    CarPuter Progress:
    Oct 2005
    UK
    Some of the earlier diesel BMW's are ISO, but unfortunately only some...
    Do you know what ECU your BM uses? It will be a DDE, but which one?
    Nov 2006
    Wales, UK
    Bear in mind registered date isn't build date. so you may be borderline.
    thanks, may have a solution as this one seems to support all the major protocols, and if the interiour obd2 isnt live it wont matter, because this one offers a wireless connection...
    anyone tried wireless obd2 before?
    http://allobd.com/proddetail.asp?prod=ST-421600
    CarPuter Progress:
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It still needs the OBDII protcol to be active in the engine management side.
    I aslo think that unit still will only connect to the OBDII socket inside the car, not in the engine bay. The wireless just means you don't need to have the PC/Laptop in the car, just the scanner and bluetooth dongle.
    Oct 2005
    UK
    The answer really is in finding out what engine management system you have.
    Enforcer is completely right, the Bluetooth is to do with the connection between your computer and the tool, not the tool and the car.
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 05-24-2012, 11:59 PM
  2. Project BMW E46
    By zaid175 in forum Newbie
    Last Post: 03-09-2007, 10:04 AM
  3. Replies: 3
    Last Post: 02-06-2007, 06:40 PM
  4. Replies: 25
    Last Post: 07-30-2006, 05:25 PM
  5. FS: Complete bmw e46 carputer system
    By RiXst3r in forum Classified Archive
    Last Post: 07-19-2005, 09:28 PM
