Results 1 to 8 of 8
Thread: Is My Volvo S40 2002 OBD2 compliant?
    Newbie mountainmachine's Avatar
    Sep 2006
    Glasgow, Scotland, UK
    Question Is My Volvo S40 2002 OBD2 compliant?
    Ok so was told by and eBay seller that my car was compliant, sent tool, cant get it to read codes, garage had no problems reading codes etc.
    Car is:
    Volvo S40 2.0L Turbo 2002 Petrol UK Model.
    Tool i bought was this:
    LINKY
    All it does is connect then go through the 4 protocols:
    ISO-1941-2,KWP2000,VPW and PWM
    But says it cant find any...
    I need some help.
    MountainMachine - Because its there!
    _
    Mar 2004
    Little Elm, Texas
    Any vehicle after 1996 is OBD-II complient.
    The garage was able to read it because they have a dedicated tool for it.
    The volvo might have an advanced protocal, much like the VWs. You should still be able to connect.
    Try the tool on another car and see if you have the same issues...if so, you have issues with your car. If it doesn't work, it's the tool.
    Jan Bennett
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by RedGTiVR6 View Post
    Any vehicle after 1996 is OBD-II compliant.
    Even a UK model?
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    VENDOR - OBDPros
    Mar 2006
    I think UK did not mandate OBD II until 2003 or so (does someone know the exact date?)
    If the volvo was compatible it would have scanned fine under the ISO protocol, I would venture that this volvo is most likely not OBD II compliant. There was another thread where the poster could not get his 2002 Volvo to work either
    Volvo V40 2002
    Paul
    www.obdpros.com
    Oct 2005
    UK
    The UK was required to be OBD2 compliant in 2001 (petrol vehicles), however this was 2004 for diesel vehicles.
    Is your car a diesel mountainmachine?
    Gareth
    Sep 2006
    Quote Originally Posted by UKOBD View Post
    Gareth
    Nope petrol, and yes from UK so unlike the US not the law in 1996, sadly!
    Oct 2005
    UK
    You shouldn't be having an issue, unless the tool is faulty.
    Best bet is to have a check of the pins present in your plug - have a look here
    for details of determining the protocol that you car uses (should be ISO).
    I hope that this helps!
    Gareth
    P.S. To clear up from the above, EU cars were required to be EOBD/OBD2 compliant from 2001.
    Jun 2004
    check and/or write in the english forum on x40nordic. I bet they can help.
  1. OBD port on '03 Volvo s40
    By johno12345 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-05-2009, 08:10 AM
  2. 2005 Volvo s40
    By mJrO in forum Worklogs
    Last Post: 05-02-2007, 09:00 AM
  3. Volvo V40 2002
    By Rik in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-31-2006, 04:41 PM
  4. 2005 Volvo S40
    By plopy in forum Newbie
    Last Post: 11-28-2005, 07:03 PM
  5. Suggestions on Volvo S40 05 Backup Cam
    By silv3rman in forum Input Devices
    Last Post: 06-22-2005, 09:06 PM
