Results 1 to 4 of 4
Thread: Gm Class 2 Data Bus Help?
    Mar 2007
    dc
    I have 06 Impala I pulled out the factory radio because the CD player would skip for any reason: going up hill/down making a turn for any reason....Is there OBD-2 reader that will reset the tire pressure and oil change light which are currently on right now? or do I just need to swap in/out the factor radio....or relocate with that metra kit Metra 70-2003t
    VENDOR - OBDPros
    Mar 2006
    On a number of gm vehicles depressing the accelerator pedal all the way while ignition is on a couple of times will turn off the oil change light.
    For tire pressure can't you just get the tires inflated to the right pressure? That should turn off the light or am I missing something
    Paul
    www.obdpros.com
    Mar 2007
    Im not sure about an 06, but I know for a fact that on many computer controlled vehicles, you can disconnect the car battery for 30 seconds. This resets the computer and clears the codes that caused the lights.
    Jul 2004
    Quote Originally Posted by dj_drj View Post
    A OBDII device will give you the option to reset the ECM computer. I did it lots of times. You will reset only the trouble codes stored in the ECM.
    I have the 2003 Impala, slightly different.
    2003 Black Impala
  1. Renault "Tuner List" Head Unit/CD changer hacking - Controls
    By Vicne in forum Hardware Development
    Last Post: 12-29-2015, 01:33 AM
  2. How to use your VERIZON cell for FREE internet
    By racerboy6996 in forum Wireless Communications
    Last Post: 05-30-2010, 07:20 PM
  3. Class 2 data bus? J1850?
    By Rickertsen2 in forum Hardware Development
    Last Post: 07-15-2005, 05:28 PM
  4. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  5. VOICES Traffic Data
    By stevieg in forum V.O.I.C.E.S
    Last Post: 05-31-2004, 09:24 PM
