You are going to be looking at specialist tools for this level of functionality I'm afraid Banshee.
DTC retrieval via the hyperterminal is perfectly possible.
I hope that his helps.
Gareth
Well is there any special OBD communication which will allow me to control the car? like for example communicate with the NAV in a porsche cayenne?
and for getting the DTC codes using the hyperterminal for instance I shall write something special like 03 something to retrieve special codes
Why I am asking is cause there are some tools to be connected to the OBD and then to activate the TV while in motion![]()
Gareth
u mean to get the general codes or the special enhanced codes?
and by any chance can I get any system architect or block diagram? I mean like:
ECU ---> CLUSTER
v
AIRBAG
