Results 1 to 7 of 7
Thread: Using OBDII connector for Charging Source
    Mar 2007
    Hi All,
    New to the forum and I would like to start out with a wierd request for comments, first a bit of background.
    I have a customer who wants our company to develope a rechargeable flashlight that would plug into the OBD connector for power to recharge the light. This would be very small and would require very little current but would reside in the connector until needed. I assume that this would be marketed as a giveaway or promo item.
    Besides a few of the obvious issues (being in the way of your legs, connector located behind a panel or in ashtray compartment) can anyone think of some valid issues that I can use to discourage this waste of time? Or is this something anyone thinks is a good idea?
    Thanks in advance
    Mar 2007
    most/all cars will have a cigarette sockets which cost little money to replace if broken with relative ease, the same cannot be said for OBD2.
    This is a stupid idea.
    Nov 2005
    UK
    i'd go with the cig lighter idea too. I'm sure you could make (if it doesnt already exist) a torch the exact size of the actual cig lighter.
    VENDOR - OBDPros
    Mar 2006
    Cig lighter might be an alternative except I think the idea is to leave the cig port available for other accessories like a Cell charger etc so from that view point this might not be an extremely stupid idea.
    Paul
    www.obdpros.com
    Newbie The6's Avatar
    Mar 2006
    UK
    Quote Originally Posted by michbound View Post
    Paul
    OBDPros
    So why not just add another cig lighter port somewhere.
    Mar 2007
    in that case add a daisy chain type input on your device so you can run another device through.
    obd 2 ports are sometimes in odd places so its not as practical either.
    VENDOR - OBDPros
    Mar 2006
    The6 & Lowtechguy,
    You guy's have a point , I was just trying to guess at the OP's motivations.
    Paul
    OBDPros
  1. Open Source OBDII scanner
    By Trampas in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-22-2011, 05:01 AM
  2. Open source OBDII
    Last Post: 11-16-2006, 10:00 AM
  3. Read OBDII Source Code?
    By Zharvek in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-19-2005, 07:31 PM
  4. GPS:MM shutdown RR when switch skin
    By MatrixPC in forum RR Bug Tracker
    Last Post: 05-12-2005, 11:07 AM
  5. master volume doesnīt work
    By free2world8000 in forum RR Bug Tracker
    Last Post: 02-17-2005, 12:08 PM
