Results 1 to 5 of 5
Thread: what handheld devices are compatible
    Mar 2007
    Hi everyone.
    I have the usb connection OBD reader and use this with my brothers laptop.
    However is there a hand held device I can use instead with software available for PC's and what devices are available?
    ie PSP, PALM, IPAQ etc?
    Mok
    Mok is offline
    Mar 2007
    It helps if you tell what kind of OBD reader you have.
    But chances are you will not be able to use it on any PDA.
    Serial OBD2 interface is a better choice when you need to use it with PDA.
    If you need USB, just buy a USB to Serial Converter.
    Most USB OBD2 Interfaces use a converter chip anyway and you do not have any speed advantage over serial.
    Regards,
    Mok
    http://scantool.imechatronics.com
    Mar 2007
    I have the top one on this page:
    http://www.obd-diag.de/
    I am just sick of dragging round a laptop and wanted to know if any handheld devices work well, what do other people use etc?
    many thanks,
    Mok
    Mok is offline
    Mar 2007
    No, it won't work with any pda.
    get an Elm based serial or bluetooth interface if you want to use a PDA.
    PDA serial hotsync cables can be hard to come by for some PDAs. So if your PDA supports bluetooth, it's better to invest in a Bluetooth interface. The bluetooth interface will connect to a PC just fine as well.
    VENDOR - OBDPros
    Mar 2006
    Mok is correct the USB interface will not work with any PDA's, since the PDA behaves as a client USB device and expects to be connected to a host.
    We make a serial interface that works with PDA's and Pocket PC's, you can find it at www.obdpros.com
    Paul
    www.obdpros.com
  1. Control devices via LPT and Bluetooth
    By Towar in forum Software & Software Development
    Last Post: 08-25-2008, 12:51 PM
  2. Replies: 4
    Last Post: 12-11-2006, 04:47 PM
  3. Too many USB devices
    By Dragonknell911 in forum General Hardware Discussion
    Last Post: 02-18-2006, 04:50 PM
  4. Can we get a forum devoted to input devices?
    By CA 3000GT in forum Mp3car Forum Suggestions/Comments
    Last Post: 01-27-2003, 03:40 AM
